3.0 SC alternator fan removal?
Is it possible to remove the alternator fan without removing the complete shroud assembly on a 911 3.0 SC?
I have seen articles on removing the complete alternator assembly but not one on removing just the fan.
1978 Porsche 911 SC Coupe.
Old 11-29-2011, 02:44 PM
Laneco's Avatar
The fan, fan housing, and alternator all can be removed on a 3.0 SC while leaving the entire shroud in place. By shroud, I assume you are talking about he big plastic piece that goes over the top and then under every single piece of the intake - right? If yes - then you can remove as I described.
angela
Hello
Old 11-29-2011, 03:12 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Yes you can just remove the fan and leave the supporting ring/housing in place. Remove the pulley and belt as you normally would. What you're left with is the fan on the shaft. The fan is keyed in place with a woodruff key (looks like a small metal pellet or tic tac) so you have to firmly grab the fan and patiently wiggle it off the shaft. It takes a while to wiggle free because the fan hub and shaft fit is a precise, tight slip-fit.
Kevin L
'86 Carrera "Larry"
Old 11-29-2011, 03:22 PM
Fleabit peanut monkey
Bob Kontak's Avatar
If you just want to pop the fan off it can be done but it likes to stick on there because of the keyway in the shaft. Tap on the fan gently (lead or brass) while pulling on the blades with your fingers.
Edit - Go with KTL's advice first.
Thanks for the replies and advice guys. I will give it a go over the next couple of days
Old 11-29-2011, 03:45 PM
Place a couple of rags under the fan - in the space below - to catch the woodruff key > cause it WILL fall in the most inaccessible place - or have a magnetic pick up tool
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 11-29-2011, 04:08 PM
some slip right off and some are rusted tight.
206 637 4071
Old 11-29-2011, 06:55 PM
Bob Kontak's Avatar
Incorrect. AND have a magnetic pic up tool. Murphy's law applies big time.
Old 11-29-2011, 07:14 PM
Brown747's Avatar
To remove my stubborn fan I tapped out 2 holes 180 deg opposite of each other in the fan with a 6mm tap then used a couple of 6mm bolts turned in evenly to work the fan free..
HTH Thor
1978 SC coupe #1834
Old 11-30-2011, 02:26 AM
I suspect you might find it easier to just remove the whole fan/alternator/fan housing assembly. Especially if that fan had been on there a while....
Old 11-30-2011, 05:17 AM
Ancient thread, but todays problem for me. Fan stuck on tight on my '85 930!
I did get if off as follows:
0. Microfiber towels packed below the assembly to catch the key if it drops
1. PB Blaster
2. Tapping gently on shaft and inner fan with a small brass hammer (put the nut on the shaft first)
3. Simultaneously pulling while tapping.
4. Rotate the fan so the key is UP when it starts to loosen and come off to try and stop the key from falling. This and the PB blaster and my key just stuck right to the top, grabbed it with a magnet.
New problem:
I guess the 930 engine sits back in the engine compartment a bit more, so while the fan is now completely undone, there is not enough clearance to actually remove it from the shaft/engine bay.
Any ideas, other than dropping the motor or removing bodywork??
2014 911 (991) Turbo S, Agate Grey
2008 911 (997) Turbo, GT Silver
2002 911 (996) Turbo, Polar Silver
2001 911 (996) Turbo, Arctic Silver
1985 911 (930) Turbo, Guards Red
Old 03-31-2025, 07:24 PM
Jeff Alton's Avatar
Remove the housing, fan and alternator as a unit. Separate on the the bench= easy.
www.turn3autosport.com
Old 04-01-2025, 06:09 PM
That's the shizzle. Never pull/pry on the blades.
Old 04-01-2025, 09:04 PM
Jeff Alton's Avatar
^^^^ heat the fan hub area. Tap it gently off the alternator.... Lost count of how many we have done this way... Quick and easy.
Old 04-01-2025, 09:18 PM
heating/tapping worked great for getting the fan off the shaft...
My problem is that although off the shaft, the fan won't clear to remove it. Yes, i could remove the entire housing/alternator/fan, but honestly was just looking to quickly swap the fan itself for a non painted one.
It's tantalizingly close, but will not clear.
Old 04-01-2025, 11:46 PM
Still here
pmax's Avatar
Well, if you're hell bent on NOT removing the housing from the shroud, I suppose you can try loosening the engine mount bolts and lowering the engine so the crossmember is no longer in the way ... or you can simply reinsert the fan and remove the unit as a whole.
Your choice
I recommend the latter.
Old 04-02-2025, 12:12 AM
917_Langheck's Avatar
Loosen the band strap and remove the fasteners to the fiberglass engine shroud. Then push the top of the fan nacel back towards the front of the car and remove the fan.
Old 04-02-2025, 12:20 AM
