Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Weltmeister rear suspension bushings - (inside)
Need some guiding advice. I purchased a set of Weltmeister rear suspension bushing for the inside of the banana arms on my 86 911. See picture below. Now the bushings do not come or are designed for an internal sleeve so this means the through bolt is not being torqued down to anything solid, just the bushing material itself. The bushings have a built in "washer" but the assembled width of the arm and bushings is .100" less than the mounting "ears" so they must draw in that much to contact the bushings. I checked with Pelican tech support (thanks Bob T) and he has not installed these and suggested this forum. In my opinion, not having an internal sleeve makes these not a very safe prospect, am I missing something here? Anyone else have experience with these particulars ones? All input always appreciated.
Old 01-12-2009, 12:29 PM
Chuck Moreland's Avatar
Do not use those bushings.
In addition to the legitimate issues you've identified, those bushings do not allow articulation on multiple axis as is required of that joint.
The axis of that joint changes with the alignment setting, and the bushing provides no means to accomodate the change - except to crush the very incompressible polyurethane. The result is binding.
Any car that is equipped with those bushings will be very difficult to align and will not have free suspension movement.
They are completely unsuited to the application and should be withdrawn from the market.
Use rubber bushings (as OEM) or monoballs for a high performance solution.
Chuck Moreland - elephantracing.com - vonnen.com
Old 01-12-2009, 01:04 PM
Carrerax's Avatar
Damn, I also bought a set of those. Thanks Chuck! Also, looking forward to getting my front A arm bushings from you.
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 01-12-2009, 01:16 PM
Thanks for the advice Chuck. I should have mentioned there are some really fine PB bushing going in front and rear, maybe you know the company that makes them (just funnin ya)! Needless to say, the Weltmeister bushings are not going in my car. Now to work on a return of parts not needed or wanted.
Old 01-12-2009, 06:11 PM
Bibi
Hi,
Instead of welmeister there is:
Pelican Parts - Product Information: 901-331-059-00-M253
Anyone know ?
Is this quality parts ?
Old 02-01-2012, 10:41 AM
Crap...have the same ones sitting here on my desk as well. Glad they are cheap...maybe I can use them for something else...
At least I didn't install them and find out they are useless, UNLIKE my little project on installing the spring plate bushings.
EDIT...useless is the wrong term, noisy PITA is more accurate.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 02-01-2012, 11:48 AM
Home of the Whopper
I have about 20 track weekends on mine with no problems. Guess I am lucky.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 02-01-2012, 11:57 AM
Bibi
Thank for your answers !!
But quality or not ??
Can I buy them ?
Old 02-01-2012, 12:21 PM
Less brakes, more gas!
euro911sc's Avatar
Those are fine Frenchi. They are the OEM ones and rubber which allow the movement Chuck is referring to.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 02-01-2012, 12:37 PM
Bibi
Ok but there is a big difference about price 22.75$ for this, against 47,50$ for OEM parts why?
Old 02-01-2012, 02:52 PM
AutoBahned
RWebb's Avatar
for the same reason that a wonderful chicken from Bresse costs more than some factory-farmed hunk of tasteless, contaminated meat from elsewhere
Quality costs more
Old 02-01-2012, 03:49 PM
French Import
zippy_gg's Avatar
Because these are URO, and personally I would stay away from anything URO. Go OEM if you want or check out the Elephant Racing site for more options.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 02-01-2012, 03:51 PM
proffighter's Avatar
Hi,
Anyone know ?
This is not the right one. This one is for the trailing arm inner end near tranny...
Roland
930 Turbo '81 Too many modifications to list
Old 02-02-2012, 01:28 AM
Chuck
I agree 100%, but I wonder that there are even worse (under this point of view) products like ER polybronze or needle bearings
Roland
Old 02-02-2012, 01:30 AM
safe's Avatar
You missunderstand, the bushing at the top is for the "trailing arm inner end near tranny".
Chuck
The bushing you are thinking of is only a 1-axis joint, Polybronz work perfect there.
Magnus
Old 02-02-2012, 01:39 AM
Targa Time's Avatar
Sometimes I think you guys sweat the details too much. I installed a complete set of Weltmeister bushings, front and rear 15 years ago. After 25,000 miles the only issue I have had is having to lube the bushings every 5 years. And by the way the handling was much improved over the beat down rubber OEM bushing.
81 Targa, Bamboo Beige, 3.2 SS
Old 02-02-2012, 01:49 AM
You're right... Sorry
Wrong!! As the hub travel describes an arc, the outer bearing cannot be a 1-axis joint. Just look lift your 911 and look at it from behind: A lot of positive camber. This would not be possible, when travel would be straight
PS: But Polybronze works fine, yes. In thise case the spring plates are bending and compensates the angle
Roland
Old 02-02-2012, 02:06 AM
safe's Avatar
I think the spring plate is designed to handle this deflection, but hopefully Chuck can add some wisdom about that.
Magnus
Old 02-02-2012, 06:00 AM
Correct.
To confirm, here you can see that the wheel/hub is making a 3-axis movement
Roland
Old 02-02-2012, 06:57 AM
Max Sluiter
Flieger's Avatar
The spring plate is designed to twist, even with the rubber bushings. The torsion bar is meant to stay straight so the polybronze helps there over the rubber.
Old 02-02-2012, 09:49 AM
