![]() i hope i have loaded the image OK. shows the locking ring that you slide with a screwdriver to unlock the mirror glass from the body. its not too difficult to remove the glass once you get the locking ring to move. |
My 85 was the three prong type. The Bentley manual does even mention it as a possibility. I fought for a long time trying to rotate a ring that was not there. In the end I figured out it was the three prong type.
I would love to find the engineer that decided that humongous connector was a good idea and slap him. To remove the mirror base to paint it you have to either cut the wires (wrong way) or find the proper size connector tool to get the individual wires out of there.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I would bet your 81 has the older style pin prong style like my 85. I thing the change over was 86 or 87 to the ring type.
The one from the Amazon link is the correct size - I ordered that exact one and it worked fine
1988 911 Carrera, M491 Cabriolet 2016 Cayenne |
Thanks, all. Working on driver's side this weekend...
Spiderman
![]() ![]() Mine are identical to what basher posted above. Wish I'd been a bit more patient with removal. I broke one little tab inside but it seems OK and maybe will glue back on re-install. As others write, slender screw-drive you need to rotate that lighter black ring. You can see the little indents on the bottom. It rotates about 1/4" or so which allows the 4 female slots to pass by the 4 males for the mirror to remove. Good bit of wiggling to get it to fall out for some reason (everything is like this). My plastic on my heater plugs was "goo" so disintegrated when pulled on. Again, will likely remove them completely during re-install. Otherwise flag mirror removal is done. I ended up cutting the wires as the pin removal tool was useless, does not work with my connector. Loosen the mirror clamp bolt and they come right off. ![]() ![]() ![]() This photo humorous. One side using Torx and the other phillips screws holding flag to the swivel base. From the factory, this has never been apart.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Also FYI the ring type mirror flag castings (and pedestal) are are thinner metal section and noticeably lighter, weight saving to avoid the fractures of the door sheet metal from the heavy early flag mirrors.
Another slap on the head. BTW if no hole in the bottom of the flag then its the early snap in type.
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
I am working on this right now, can anybody please tell me how to pop out the three prong configuration mirror?
I was asked about the pin tool that I posted about earlier, so I went through my pics.
It's actually a "Stahlwille" "Kabelex". I got it from Baum Tools. They just sent me the whole Stahlwille catalog, which I don't have but maybe it's online. There a handle, and a tube shaped ejector. You want to order the correct diameter. ![]() ![]() ![]() And while I'm at it, here's how to eject the wires from a Blaupunkt old school head unit connector without damaging the now NLA connector. ![]()
Use a plastic spatula or something that is flexible, and wide enough to support the glass. Pry and pull the mirror out with that. I use either a burger flipper spatula or the one that came with my George Foreman Grill, which is perfect for the job.
OK here we go. Appears that I posted this before. I'm starting to forget past projects, lol.
I think it's the 1.5 mm contact. The tool outside diameter is 3.0 mm. The handle is part # 1501. That would mean that the head (for the aircooled 911) is 1511.
Hi
One of my pins on the connector is crushed. Where can I get some, Is there a name, size or code that I need to look for ? |
Hi
I'm good with tools.
I got luck and was able to scavenge an old harness for some.....
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
I also bought the Lisle 56500 tool. Although it fits perfectly, it does not dislodge the pin. Not sure if I need to pull harder on the wire since the concept of the tube compressing the little protrusions should work.
![]() Thoughts... suggestions? |
The "Stahlwille" "Kabelex" is the right tool. Kinda spendy, but it will save a lot of effort and prevent cutting the wires.
https://www.amazon.com/Stahlwille-TOOL-KABELEX-1501N-1511/dp/B007925V5G $48.25 plus 20 bucks shipping. Basically $70 for one tool. Wow. I am a tool lover, but wow, that is a lot.
