The oil lines were fabricated by Greg @ Precision Motorwerks in Fullerton CA.
The AN to metric adapter is integrated with a rotational collar in the 90 degree fitting for minimal fitting length and the needed fitting orientation. The oil line from the tank is also partially recessed into the CUT tub frame rail and enclosed in high density foam with a rubberized coating. This mod allow me to run Pirelli 315/680 slicks or even the 70's from Michelin without rubbing the AN-16 hose in a CCW direction on the racetrack. WHY DONE: I'm not gonna be the guy whose tire inadvertently shreds and flails the stock oil lines to death and puts the guy behind me into an oily track situation, seen it before, peace out
1980 911 - Metzger 3.6L 2016 Cayman S |
Resurrecting this thread guys.Im definately installing braided hoses (oil lines) on my 78SC.Will obviously run from Carrera Oil cooler.I have seen a few examples of lines, running under sills.Anyone tried this.Experiences?
Vintage Owner
As braided lines will not transfer as much heat as the original hard lines, why replace them? I’d think every little bit of cooling helps.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
From past installs I've seen, flex hose is usually larger than the factory metal tubes and can't hug the chassis as closely, esp. under the jack receptacle. A large radius is a result and thus very visible, especially w/braided SS hose, and to some, untidy.
![]() It's a lot more work, but routing hose through the lower chassis structure is one option. Sherwood |
Braided lines won’t provide the cooling the original hardline or the elephant racing do
Sherwood |
my 78 project car had these steel braided lines. will replace with correct metal lines. considering the ER 'finned' lines.
anyone have experience with the 'finned' lines? if anyone wants the old lines they can have them for shipping.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
Vintage Owner
The finned lines should help with heat transfer. Back in the 80s, Lemke Design sold a Turbotrol finned oil cooler kit that was a popular retrofit to the 2.7s that Porsche didn’t think we needed in the USA (due in part with our 55mph speed limit in those dark days).
I recently added the ER finned fines to my build they look nice we’ll see how they perform. Keep in mind though that the O.D. of the lines are larger than the original.
78 911 st backdate 87 944 00 996 |
Much of the cooling is done by the lines. Thats why the original oil cooler was the trumbone which was just more brass lines.. braded lines are a downgrade.
Chris |
Oil Cooler
Just a thought, why not install a oil cooler under the decklid just like they do with the aircond condenser ? Shorter oil lines, more air with ducktail or whale tail.
Sherwood |
![]() I just don't wanna be that guy that dumps oil at all cost, someone else can get hurt badly. ![]() Full length AN 20 stainless steel braided lines rerouted help minimize that risk for me. Also by replacing the oil tank fitting and tucking it into the tub opening, I can fit 315 slicks within my turbo flares and run full suspension loading with no rub
