What Size/ Fitting is this 75 CIS Fuel Return Line
I’m working on figuring out the correct fitting for the return line.
It’s the solid hardline that transitions from soft hose to hard line.
So far I’ve tried a 6AN flare to 6AN ORB male O-ring adapter, as well as 6AN to 14mm, but nothing fits. It looks like some kind of compression fitting, but I can’t pin down the size. Ultimately, I need to adapt it to 6AN.
The odd part is that on the return line I used when pulling the new 6AN hoses, the factory male connection spun onto the 6AN line fairly easily — not a seal, but enough to pull the line through.
Old 09-18-2025, 07:57 AM
Return Fuel Line Fitting………
Louis,
The return line fitting in your picture is a 14-mm x 1.5 compression fitting.
Tony
Old 09-18-2025, 02:01 PM
Thanks Tony, Ill updated on my main build/trouble shooting thread.
But I got the front pump mount/tunnel lines run (That was fun and now just need to complete the rear.
THanks
L
Old 09-18-2025, 03:39 PM
