911 SC question
Hello.
There's a 1981 911 european SC for sale in my region for a pretty good price, but with two broken head studs (common for these models I believe). The rest of the car seems very clean. My questions : are broken head studs a big issues on SC ? How much could it cost me to fix it ? Would you guys repair it on a rush, can it wait a little ? Do you just replace the studs just like that or it requires other parts to be replaced ? Thanks again ! Nico
1985 911 Targa (sold) 2001 996 Twin Turbo (sold) 2001 996 C4 Last edited by Nico911; 11-14-2012 at 05:49 PM.. |
From threads I have seen most people will say just two broken studs is not a big concern and car can be drivin without worry
I assume that all other studs have been checked for proper torque?
Justin 84 Carrera Targa 98 F-150 4x4 |
I'll ask... thanks !
1985 911 Targa (sold) 2001 996 Twin Turbo (sold) 2001 996 C4 |
bump !
ROW '78 911 Targa
Do a search in the engine rebuilding forum. Depending on the severety and location of the broken studs you can do enough damage running that way, extensive machining may be needed.
For cost, it depends on how much you can do yourself. Drop the car off at a mechanic=$5,000 Drop the engine off at a mechanic=$4000 Buy all needed tools and do it yourself=$3500 and the value of the experience. Have all tools and do it yourself=$1000 for parts if you don't get bitten by the "while you are in there" bug...
Just went through this with my 81sc. Short answer is it needs to be fixed, or you risk damaging the engine. To fix it the engine needs to come out, the heads are pulled, all the studs are replaced.
Of course while its apart any reputable mechanic will recommend a valve job and reseal. Also might as well replace the clutch disc plate and throw out. You will also find other problems like worn cv boots, mounts, crumbling sound inslulation pads, worn hoses etc. I feel as though I resisted 'while your in there' syndrome as much as possible and ended up spending $5000+ |
My experience from reading here is that you can't get as much value out of the car than you put into it by fixing it. If you buy the car for 8K and put 5K into rebuilding the engine, the resulting car is not worth 13K. There are great priced SCs out there with rebuilds and no broken headstuds. I'd suggest you keep looking.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! |
Kurt |
where are these awesome priced SC's - seems like th market has done an uptick again in recent months....
Shane - 1984 928S |
ROW '78 911 Targa
Code:
Contacted Year Type Price Location 1979 Targa 12000 Raleigh, NC 1981 Targa 13000 Los Angelos, CA 1981 Targa 11900 Philadelphia, PA 1981 Targa 8500 Raleigh, NC 1980 Coupe 13000 Lexington Park, MD 1983 Cabriolet 12500 North Chicago 1979 Targa 9500 Minneapolis Uncontacted 1982 Targa 12500 Washington DC 1982 Targa 12900 Phoenix, AZ 1978 Targa 12500 Austin, TX 1980 Targa 14000 Dallas, TX 1982 Targa 14200 Atlanta, GA 1979 Coupe 12500 Fairport, NY 1978 Targa 11000 Middleton, MA 1980 Targa 11500 Los Gatos, CA 1983 Targa 13900 Overland Park, KA 1984 Targa 12500 LA, CA 1981 Targa 12950 Denver, CO
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! Last edited by OsoMoore; 11-15-2012 at 08:17 AM.. |
I would only like to add that the '81-'83 RoW SC's came with the very desireable 930/10 204 hp engine. These were the most powerful of the SC 3.0 and not easy to find. IMO, this does add to the value and desireability if you're up to the task of replacing the headstuds.
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
As the owner of an 82 911SC (USA version) currently undergoing head stud replacement, and if I had the opportunity all over again to shop for an SC, this would be my approach:
1) Contact your insurance agent and get a firm quote on the required insurance. This I did, and since I'm in the near age 50 group with multiple cars it wasn't shall we say "unreasonable" for the required/desired coverage. If you are less than say 30 years old and this will be your only car.....watch out! 2) Replacing the head studs will require the engine to be torn down to at least the "short block" i.e. case and crankshaft. a) Check the engine ID number to make sure it is indeed a ROW engine. b) Perhaps others can confirm what should be there with a ROW engine should the ID indicate, search the 911 engine rebuilding forum and learn how to distinguish, by counting the cooling fins of the cylinders from underneath the car, whether or not the engine has the Mahle or KS pistons and cylinders. If they turn out to be the KS versions that can be a whole 'nother world of hurt; again search the rebuild forum for the 29 page thread on re-ringing KS pistons and cylinders. IF they turn out to be the Mahle version you might be ahead of the game for step c. c) Get a competent 911 mechanic to perform a compression and leak down test as part of the PPI (Pre Purchase Inspection). If you've made it this far, it's all about the final $$$$$ negotiations. |
At the end of the day it will probably turn out to be repairable, but your decision should be based on the overall results of the PPI. What condition is the trans in? Suspension, brakes etc. This car is probably worth over $20,000 in absolutely original, well sorted out condition, with good paint $ interior. Yea there are a lot of project cars out there for less (many in desperate of top end jobs), but I think you should base your decision on what the car could be worth if all its problems are solved. If at the end of the day it will cost more fix it then it will ever be worth move on. Good news is there are a lot of very nice SC cars out there, if that's what your after. |
Get a PPI though. Tranny rebuilds are $3500. Clutches are $650 in parts. If EVERYTHING else is good on the car and the price is right, you might be able to come out on the other end without overpaying. If something else is wrong, you're going to be upside down on it. That's fine if this is the exact car you want (god knows I'm upside down on my car), but don't expect to be getting a deal. Also, as someone else mentioned, insurance is cheap. Mine actually went down when I put the 911 on my insurance and I have full coverage. |
83 Targa
I love this discussion, but as a new owner of an SC, I hear conflicting stories. It seems as if broken head studs are innevitable, yet most say this engine is bullet proof. $5000 in pending repairs should make any engine bullet proof. Either way I love the car and the way the engine just sings going down the road. Other than pulling valve covers, are there other tell tale signs for broken head studs? What percentage of 3.0's get broken head studs?
I wanted this car since before I could drive, and here I am 36 years later with a gaurds red targa. Its justified as my safe version of a motorcycle..... |
Yes, they have a reputation for reliability. However, they're all approaching 30+ years old. Maintenance is due on all of them. if you want to get one that's truly bulletproof, buy one that's had an engine rebuild and documented head stud replacement. The only way to really tell if they have broken studs is to take off the valve covers. It'll be the lower set that breaks. Even if there aren't any broken studs, that's no guarantee that they won't break in the future. |
