flash951's Avatar
Just the tip I needed right now. Tomorrow my Dansk muffler will have straps
Remi Jakobsen
911T DP targa -71 (2.7L)
Phone: +47 92844671 (Norway)
Old 07-29-2010, 01:56 PM
911SC '82
I dont understand why the author simply didn't buy longer stainless steel bolts and problem solved.
Old 06-05-2024, 11:53 AM
proporsche's Avatar
Oh dear,it is obvious that you do not know Wayne the founder of this company "Pelican...parts"....??
1985 911 with original 502 191 miles...808 198 km
Old 06-05-2024, 12:25 PM
And Wayne D. got his engineering degree from MIT.
Tony
Old 06-05-2024, 03:21 PM
917_Langheck's Avatar
Except that he did indeed buy longer bolts to address the shape of the band, which is the issue, preventing the use of the proper fastener, which is the one you want to use as it is shorter, making it easier to remove, and fractionally lighter.
So, like when installing new sping plates and bushes, use the LONGER bolt to seat the part, remove and replace with the proper bolt when it comes time to button up.
Why is that unacceptable?
Old 06-05-2024, 03:44 PM
PCA Member since 1988
Extra work.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-07-2024, 05:24 PM
Still here
pmax's Avatar
Why not ?
Cause it's unnecessary weight.
Old 06-07-2024, 05:35 PM
