And I managed to get the whole assembly re-installed into the car. Huge improvement!
Brian Miller - Scottsdale, AZ 1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S |
Took My Porsche out for a morning cruise. 3 hours 160 miles non-stop. Car ran great cruising 70mph. The whole way. Used just over a half
tank
I am all thumbs, and have to change the IAC on a 1988 911. Should I not even attempt to do it myself?
83 911 Production Cab #10
It must be my lucky day…
No heat, PB blaster, 2 tap at the end of the stud (5oz hammer) and a stud extractor: 12 Steel Studs on top and 12 Divilar Studs at the bottom...
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Installed the Long Beach radio from Retro Sound. Includes SiriusXM, iPhone compatibility, 2 USB ports, Bluetooth, and more. Works really well. I wish they had a Porsche 911 specific install kit but I used their DIN repair kit and was able to perform a very clean install with the unit mounted solid and secure. For the casual observer it looks like a vintage OEM style radio. They have no idea it is a modern unit. Porsche enthusiasts and concours judges would notice the difference but most will not. Love the quality, features, and sound!
I still need to add some basketweave trim behind the radio bezel.
Swapped out the stock under-dash vents for the Ächtung Kraft units. A big thumbs up for these. Had the targa top off this morning at 45º and the heat was blasting my passenger and I right at our lower torso's keeping us toasty warm.
Guessing the fresh-air blast in warm temps will be equally appreciated. Definitely worth the price of admission. FYI: To make these fit on my '71 Targa I had to grind away about 1/16" from the back edge. Once I did that the fit was perfect. Stock vent on the left, Ächtung Kraft on the right. Directs the air right at you!
1966 912 with 2.2 911 motor 1986 wide body 911 1995 993 Polar Silver |
1984 3.2 cab india red 1970 1192 Volkswagen Beetle |
Finished up my Rennshift install this morning and drove to work.
First impression.....OMG why didn’t I do this sooner. I don’t know if it’s the rennshift, stomski coupler, new engine/trans mounts or a combo of them all but it’s transformed the car. The shifting has gone from “stick in a bucket of paint” to “closing the bolt on a Lee Enfield” The only issue I have is getting my old shift knob back on. It was a bear to get off (forget tapping it off with a 15mm wrench, it took a strap wrench and a lot of effort) and I can’t seem to get it all the way seated with the old crush sleeve. I’m going to try a heat gun next and as a last resort I may just spring for a new threaded knob. |
I talked my Drivers Side Spring Plate to let go
fought for 3 weeks, soaked with PB Blaster, bought $85 worth of 36" pry bars, read all of the forums, finally popped it off with $1.38 of wood shims, took all of 5 minutes
1975 914 1.8l 1979 911SC Targa - In Restoration 1972 Pantera Dune Buggy Dual Port 1835cc 1980 911SC Targa - Driver/Winter Project |
Adjusted floatbowl levels on my ZENITHS 40TIN today
Driver
Transmission fluid change and LED instrument panel lightbulbs.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
I like those LED instruments lights, I may have to include that into my spring projects.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
I’ll be changing my transmission fluid tomorrow.
_______________________________ 1982 911 SC 240,000mi and counting |
Driver
I chose the soft white bulbs.
I have a set of each in different cars. The soft white is the way to go.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
'86 Targa (Mighty Mouse) '11 997.2 Carrera S Coupe (To be named) 08 M3 - Sold "Having a sports car that you only take to car shows is like having a race horse you only take to the petting zoo" |
Pelican Parts Vendor
Put it in storage while we look for a new building
Looooong story. Untitled by Team Illuminata Motorsport, on Flickr
Paul Eddleston BRAID Wheels USA Team Illuminata Motorsport |
Noah where did you purchase your led's? Maybe manufacture and item number also. Looks great.
PJ 78 911sc Targa 70 911T |
| Tags |
| fuchs are ugly , stock sucks |
