Tracked down and fixed an annoying oil leak on the 72E. It appeared oil was seeping down the driver's side crankcase, and winding up on the bottoms of the cylinders. Took the air box off to see if something was amiss in the "triangle of death", and saw a puddle of oil in the MFI pump mount. It seems oil was leaking from the MFI pump oil line. Quick replacement, back together and off for a spirited flogging. Got back, no more burning oil smoke, no more drips on cylinders. Today, I won. Next time? meh
______________________________ Dave 1969 911T Coupe 1972 911E Targa |
I think the concept for Whack-a-Mole may have come from a 911 owner chasing leaks.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Too true!!
Took it out of the garage for a polish.
went for an early morning run thru the hills!!
2007 Cayman 1986 Carrera coupe (sold) 1979 911 SC targa (sold) |
Rescuer of old cars
What 2-out exhaust is this? Dansk?
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Gosh, wish i knew.
It was put on by the PO and I liked it. I never got around to finding out which brand it was.
1986 Carrera coupe - black on black 1972 CB500/4 |
![]() New pads and discs all around! Thanks Pelicans for the two-hammer trick to remove the front axle's grease cap... Sent from my TRS-80 Model III.
Mike '87 Guards Red Targa |
![]() Was getting way to much play up down side to side. Thought my steering wheel bushing was toast even though I'd replaced 10-15 years ago. Just happened to be a loose nut. Put lock tight on this time.
63 356 So Called Outlaw 76 930 |
Washed it. Then went to take a drive later and would not start. Thought maybe something got wet, so I waited a few hours and tried again. Cranked but no start. Swapped out my DME relay, and no luck. Tried to crank for 30 seconds and got a big BOOM as a result. Looks like I'll be getting it towed to my service place on Monday... Bummed because I am going to my first auto cross event tomorrow. Guess I am taking my daily driver -- a Saab 93.
Ongoing job,but here are some of the highlights.
![]() ![]() ![]() ![]() ![]() ![]() These are the "new 993 brake calipers sitting next to one of the old ones. ![]() Still have a long way to go!
'81 SC Euro 3.0L Twin Plug11-1 ect '78 924 project 2003 BMW 525i |
Certified User
Balanced the ITBs and retuned idle to a comfortable 800 rpm.
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S |
refitted stock radio
Only had this Porsche about 3 months now,PO had a modern CD player fitted
when i purchased car but also gave me its original Blaupunkt, so i fitted it back in this weekend,- looks far better and the way it should,may refit the CD player into the glove box soon as i never use glove box anyway. ![]()
elephant racing oil cooler kit
86FlatSix
tails is back
put the weissach tail back. Can't decide whick look I like so I just switch once a month
Got nobody to help me lift the tail to mount it so I improvised![]() ![]()
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
Installed Kuehl barrier hoses over the course of the weekend.
![]() Took me about 9 hours all-in (prep, work, distractions, beer runs, recharge, cleanup). It was a NASTY job. The old lady came out while I was working and took a picture. She told me I looked like I had been working in a coal mine. Pulled a vacuum for about an hour while I was cleaning up, then left it for an hour to see if there were any leaks. It was still holding vacuum, so I put in 43 oz of r-134a, reaching pressures of 45 low-side / 250 hi-side. While I had it up on jack stands, I swapped out the driver's side valve cover gaskets, which had been weeping. So she is ready to go for the summer.
07 Boxster 88 Carrera Cabriolet 3.2 (sold) 05 Boxster S (sold) |
Speeding Ticket
received a speeding ticket on the Autobahn today. Actually i like the pic a lot, well worth the €30.
http://www.carrera-32.com |
Pelican Parts Vendor
This is awesome. How do I get one of these?
Paul Eddleston BRAID Wheels USA Team Illuminata Motorsport |
Eva
This is hilarious.
I'd blow up and frame the photo
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
| Tags |
| fuchs are ugly , stock sucks |
