Instruments
On my 1981 SC, I have been having a problem with the oil pressure gauge needle just jumping around all over the place. I didn't think it was actually an oil pressure problem as the engine would have seized (!) but distracting anyway.
I lifted out the gauge from the dash and found a loose red/black wire another end of which led to the oil pressure light so guessed it was related & I re-attached it to a spare terminal on the gauge. It appears to work.
However, there was also a loose green wire behind there. Anybody know where that should go?
Cheers
Old 06-04-2013, 05:53 AM
El Duderino
tirwin's Avatar
David,
I don't have the wiring diagram handy but loose wires in the dash makes me cringe. For some strange reason Porsche did not design the instrument wiring to be on a fused circuit so you have a hazard on your hands. I'd suggest checking for any other surprises with your instrument wiring and look at adding a simple in-line fuse. The fuse is super easy. I'll look for the wiring diagram and the thread that shows how to install the fuse.
Old 06-04-2013, 06:32 AM
El Duderino
tirwin's Avatar
Here is a thread that shows the in-line fuse:
http://forums.pelicanparts.com/porsche-911-technical-forum/700218-fire-under-dash.html
Old 06-04-2013, 06:37 AM
El Duderino
tirwin's Avatar
Here is a link to the electrical diagrams. 78 should be the same for your 81 I believe.
Pelican Parts - Porsche 911 Parts Listings & Diagrams
Good resource on European wiring:
http://www.thesamba.com/vw/archives/info/wiring/Understanding_Euro_Wiring_Diagrams_Motor_Magazine_ April_2003.pdf
Old 06-04-2013, 07:33 AM
Thanks, Tirwin, that's brilliant. Much better diagrams than in my workshop manual. I will work it out tomorrow.
Cheers, David
Old 06-04-2013, 08:10 AM
woland's Avatar
Bouncing needle probably means faulty oil pressure sender
Look at my old post, you will find useful informations and pictures
http://forums.pelicanparts.com/porsche-911-technical-forum/520645-wiring-all-gauges-911-sc.html
Paolo from Alps
1980 911 Targa SC 3.0 - Silver metallic
1980 Ducati Pantah 500 - Red
1989 Yamaha 500 "Tracker"
Old 06-04-2013, 11:52 AM
Thanks for those links. The oil pressure gauge now works fine, it was just a loose connection on the back of the gauge.
I have taped up the disconnected wire and will wait to see what doesn't work!
Old 06-25-2013, 05:05 AM
Chief Head Scratcher
kerthunk's Avatar
My '79 has a loose green wire as well. I believe that it was just an extra in the wiring loom.
John Morris
'79 911SC
Old 06-25-2013, 09:00 AM
Tags
gauge , instrument , oil , wiring
