carrerarsr65
79 911sc /280 hp?
what do i have to do to get around 285hp out of my 911 motor, shes currently apart for spun rod bearing i already have 40 webers 2 in 2 out exhaust . so where from here twin plug? cams? open to all ideas
Old 06-24-2013, 10:53 PM
To get 280 BHP from your 3.0, you will need:
46mm Webers or PMO's or an equivalent ITB system
11:1 CR
Twin-ignition
Custom cams (there are several choices)
A set of GOOD 1 5/8 headers with a proper race muffler
A host of oiling modifications
Close attention to engine assembly detail
Close-ratio gears to keep such an engine in its powerband
A GOOD oil cooling system to maintain oil temps at or below 200 deg F.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-24-2013, 11:31 PM
..........or a 350 Chevy.
Just kidding.
Old 06-25-2013, 02:42 AM
Northern Motorhead
wildcat077's Avatar
I had the same thoughts regarding my 3.2 and realized it was more cost efficient to just install a solid 3.6 with hydraulic lifters ...
Otherwise it's basically what Steve mentions plus a lot of $$$
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 06-25-2013, 04:21 AM
3.8 Variram....
63 356 2.1 Rally Coupe
75 911M 2.7 MFI
86 Sports Purpose Carrera "O4"
19 991.2 S
25 992.1 GT3RS
Old 06-25-2013, 04:29 AM
theiceman's Avatar
I am just amazed you had a spun bearing. Those 3.0 motors are rock solid. I do agree with masses however. Drop in a 3.6 and toughen up the gearbox.
Put your stock 3.0 back together and sell it to help offset the cost.
Anything else is an expensive proposition
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 06-25-2013, 05:09 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Make it a 3.2 (or 3.3) short stroke and you'll find it easier to hit 280. There's an old adage that says no substitute for displacement/cubic inches.
Kevin L
'86 Carrera "Larry"
Old 06-25-2013, 08:28 AM
Don't forget cubic dollars.
Old 06-25-2013, 08:48 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Very true. That's a given on these engines. If you ain't willing to spend the bucks, the stock power will have to be sufficient. There's no secret cheap path to eeking power out of these motors that hasn't been tried already.
Could do a mild turbo installation too. That isn't exactly pocket change either.
Kevin L
'86 Carrera "Larry"
Old 06-25-2013, 08:52 AM
carrerarsr65
hey kevin
what r my options on going bigger, ive been brought up racing 2 stroke dirt bikes and doing vintage road racing,there we could just bore out the cyl,and achieve greater diplacement,as of now the engine is on the stand,cases r split,just trying to get some detailed build ideas, ive thought i saw somebody using 3.2 cyls. and boring them but i think i'm goining the je piston way, any camm suggestions, oh by the way this will be a strret motor with weekend auto x man it sukks being a power junkie anyway thanks man
Old 06-25-2013, 09:26 AM
Chief Head Scratcher
kerthunk's Avatar
280 is pretty ambitious. I put some new jugs (nickies) on mine and went the 3.2SS route. Twin plugs, elgin mod-s cams, 46mm PMOs, SSIs. I went with 9.8:1 compression since it is a driver/street car and I wanted to use pump gas. I'm doing 228hp/210ft-lbs at the wheels on a dynojet. That would be something like 260hp at the crank.
In the end, it probably would have been cheaper to drop in a 3.6. But, I wanted the "old-school" look and be able to have built it myself. Plus, I have the peace of mind knowing exactly the state of all the innards of my engine.
John Morris
'79 911SC
Old 06-25-2013, 09:44 AM
Eva
911SauCy's Avatar
Solid built 3.0, EFI, and a turbo.... 400hp?!
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 06-25-2013, 10:06 AM
