Superb video of 911 RSR motor build
This is a beautiful montage of a 911 RSR race motor build from start to finish.
Great visual if you've never had one apart or built one from scratch!
Done by a German shop named Mittlemotor. 21 minutes of beauty.
Montage Porsche 911 Carrera RSR Motor - YouTube
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 02-22-2014, 07:03 PM
I don't understand the use of the heat gun while tightening the bolts on the fiberglass shroud and engine "tin". Is that supposed to reduce cracking or something?
Old 02-22-2014, 07:15 PM
correct
Old 02-22-2014, 07:29 PM
Max Sluiter
Flieger's Avatar
I don't understand not wearing a mask or glasses when using a cutting wheel on and sanding the fiberglass...
Old 02-22-2014, 07:31 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
why does it take so long to rev up when they go to wide open throttle? Must be restricting the fuel?
Old 02-22-2014, 09:12 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
He is German, they are impervious to such things.....
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 02-22-2014, 09:22 PM
Max Sluiter
Flieger's Avatar
No, that is how a real dyno works. They control the brake torque electronically. They control the engine speed by controlling the load on it. This way you can fully map all operating regimes- part throttle and full throttle, steady-state and transient.
Old 02-22-2014, 09:23 PM
Start with high load to prevent over reving, reduce load to allow engine to reach max rated RPMs under control and measure output.
Old 02-22-2014, 09:27 PM
Certified Pre-Owned
BGCarrera32's Avatar
Where is he injecting whatever it is in the syringe at 6:00?
'84 Carrera Coupe
Old 02-22-2014, 09:35 PM
michael lang's Avatar
That shop reminded me of the restoration shop at the museum. Clean, very well organized, all business and did I mention clean. They make it look so easy and they have such an abundance of tools. Watching that video definitely helps to understand how some of the things on these engines go together.
Mike
'89 CARRERA
#402
Old 02-23-2014, 02:30 AM
Agree. Nice to see a fanatically clean shop.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 02-23-2014, 02:46 AM
NOLAsc's Avatar
Any idea why the injectors are at the tops of the stacks when idling but at the heads when running up to speed? (At about 20:45.)
"... changing without pain or agony not only in bulk and shape but in color too, approaching the color of wind ...."
-- William Faulkner
Old 02-23-2014, 04:26 AM
Just noticed what you discovered, good eye. Must be two different motors.
Old 02-23-2014, 05:51 AM
kodioneill's Avatar
I was thinking the same.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-23-2014, 06:17 AM
kodioneill's Avatar
No OSHA there. I'm surprised there's no cover over the distributor hole while he's installing bolts and washers on the shroud.
1982 chiffon 911sc
Old 02-23-2014, 06:26 AM
Gary
1200images's Avatar
Great video. Thanks for posting.
9E LUVIN
Old 02-23-2014, 07:56 AM
Elombard's Avatar
Very clever to cut the hole in the back side of the shroud so he can get to the bolt on the back of the intake. Must have done this before :-).
Interesting they run no alternator on the motor (or did they not show it). So they do sprint races on the battery only?
I used to do that on my datsun running SCCA Production racing. Saved a pound and added a horsepower but it was a pain.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 02-23-2014, 09:10 AM
NOLAsc's Avatar
I'm not sure they were different motors. The video showed the head-level injectors as well as the tapping of the horns for injectors. I just wonder why they went from one spot to the other -- or why they were placed high at all. Maybe they were placed high just to confirm good flow???
-- William Faulkner
Old 02-23-2014, 06:26 PM
Max Sluiter
Flieger's Avatar
Testing power difference between the injector location. Porsche went back and forth. I guess these guys figured the low mounted were a little more drivable and didn't give up any power. 956 had an injector pointing against the flow and high mounted if I remember correctly. Needed more time to mix the fuel and air.
Old 02-23-2014, 08:13 PM
