Homebrew octane
A while ago someone(I think maybe Jack) was asking about octane boosters. I just came across this site w/ some relevant info.
Although tempting, I don't like to fool around with boosted octane levels (i.e.95+) due to the fear I have of self-ignition (i.e. compression of the fuel to a point where it ignites BEFORE the sparkplug fires - i.e. backfire).
The thought of all 6 cylinders firing like a diesel doesn't appeal to me or my wallet...... ![]() I have no experience with boosters however so other guys please comment and correct my fears accordingly if possible! Anyone had good luck with 'boosters'? I have used a Swepco gas improver, 503, which claims to allow fuel to burn more completely and therefore provide a 'boost'. It cleans injectors too. I noticed a diff in my gal's civic, but didn't do much for my 911SC.
If opportunity doesn't knock, make a door. |
Navin Johnson
errrr, higher octaners resist compressive detonation.... which is a good thing.
I run 104 in my car 9.8:1 I have used toluene and xylene as a stop gap measure,when I have run out of VP fuel. toluene and xylene are cheaper than the same repackaged products. Mix them with marvel mystery oil and off you go
http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
excellent!
i was told the opposite, seemed to make sense, and therefore have steered clear.
Re: Homebrew octane
Pardon my ignorance but can you dump a gallon in for every 10 gallons of gas without premixing, or should it be mixed prior? |
