915 transmission - synchro or linkage.
Hi folks
so here I am... an absolute newbie and keen and in need to learn on any level...
Just got a "new" 1977 911s Targa (Miss. B) with standard 915 transmission which is a bit reluctant on its 2nd gear.
In standstill all gears enter without troubles but when driving and shifting into 2 (up or down) the gear tends to pops out, or need a slight hand pressure to stay in, grinding can occur but is not always the case. Also from 10 changes 3-4 might go in nice and smooth. What I have noticed is that if one changes gear bellow 1000RPM all goes fine, no troubles...
So what would be your analysis... Tuning of shifting linkage or worn out synchro/dog tooth?
Thank you for sharing your wise know-how.
See you soon guys!
Old 06-24-2014, 07:18 AM
First and foremost, welcome to the Pelican forum. Now you know that we need a photo of your beautiful new car before we get started. But in this case I will allow an exception, LOL.
If it pops out of gear, worn synchro or dogteeth, or both.
I am so sorry to be the bearer of bad news.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 06-24-2014, 07:45 AM
That problem can be the first signs of an exploding 2nd gear synchro. IIRC, the issue became bad enough that Porsche made changes to it in the early 80s.
The Cap'n
Old 06-24-2014, 08:06 AM
Peter Zimmermann's Avatar
Drain the trans fluid and inspect the magnet on the drain plug for small metal particles that look like teeth.
Keep the Shiny Side UP!
Pete Z.
Old 06-24-2014, 10:37 AM
Nothing good comes after this statement "it pops out of gear "
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-24-2014, 11:05 AM
I recently bought my first 911 (82 SC targa) here in the UK back in April. I drove it home, 350 miles from the sellers house and was really worried after it jumped out of 1st gear a couple of times when pulling away from junctions.
I hit the web when I got home and found a range of answers.....I started with the cheapest as they were things I wanted to do anyway.
I changed the gearbox oil and the gearbox mounts, I planned to change the engine mounts but they've seized solid. Anyway, it hasn't jumped out of gear since.
My advice, based only on limited experience would be........
1. Change gearbox oil
2. Check/change gearbox and engine mounts (total of 4).....not expensive.
3. Check gear change linkage bushes for wear/play.
Got to be worth doing before committing to major surgery on the box......good luck.
Old 06-24-2014, 11:47 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Synchro wear doesn't actually cause gear pop-out directly. Worn synchros will eventually lead to crunching gears (actually it's the male dog ring teeth that clash with the shift sleeve slots to cause crunching) because the synchro has lost its ability to match gear shaft speeds for the teeth to engage the sleeve most easily. Gear crunching as a result of worn synchro bands (and/or shift sleeve) can be reduced almost entirely by slowing down your shift or double-clutching. But ultimately parts need to be replaced to eliminate the crunching.
Gear pop-out can be loss of dog ring teeth. That's why Peter said check the drain plug magnet for lost teeth stuck on there. The loss of those teeth prevents the gear from remaining engaged within the shift sleeve when power is transmitted through the gear. Or the shift fork is out of alignment and the teeth are not fully engaging the shift sleeve.
The exploding synchro saga is typically due to the synchro being forced to do too much work. Usually too worn to do it's job and actually its too much force put on the synchro & gear when coming OUT of gear. That force is caused by yanking on the shifter before the clutch is fully depressed and disconnecting power from the gear stack. Premature yanking (keep it clean, this is a family show.....) makes the big flat retaining clip flex and eventually can come off the gear. Once that clip lets go, serious carnage ensues. The trick to fixing that is converting to 930 retaining system. But that's only directly changeable on 3rd & 4th. 2nd isn't possible w/out modifying the gear.
http://forums.pelicanparts.com/porsche-911-technical-forum/753069-915-4th-gear-issues.html
Kevin L
'86 Carrera "Larry"
Old 06-24-2014, 11:56 AM
Fleabit peanut monkey
Bob Kontak's Avatar
These are my thoughts, which are simply a remix of the above.
Do what Peter says first (chunks o' metal).
I think the plugs are 17mm female allen sockets. Buy a 1/2 inch drive allen socket. I remember buying a hefty long handled 17MM wrench at an industrial supply place in Houston in the 90's. Bummer is, over time the 17MM socket holes can get beat up if reused and the 17mm allen socket can be used with an extension (or two) from outside the wheel well (top sealing plug) and you can push against the ratchet to maintain the bite where the fastener meets the tool. YMMV but that's what I found.
If you find chunks of stuff, full stop. Time for a refresh. If no chunks, craig245's comments are a worthy effort especially if you find wear in the parts he is mentioning
Skip adding a short shifter for now as they do beat on synchros a bit more than the long throw shifter.
Given you are in Houston, there are enough Pelicans around that wrench. With an offering of beer and even a modest amount of cash (no 1099's) , you may find your new best friend who will help you pull the engine and split the trans.
Whatever KTL is speaking of regarding beefing stuff up, Matt Monson (member here) can do.
Cost to UPS ship a 915 is around $125 each way. There is also a shop in west Houston, past Katy, that is highly regarded. Folks here will know.
Mayo in Dallas is also an option, but I feel Matt knows more about fussing with the synchros and dog teeth to alleviate any "break in" time for smooth operation right out of the box. Something to do with back-cutting something that does not require the synchros to wear some before smooth operation.
After all this wind, and given I know the same amount as craig245 (i.e., limited experience), this info is worth what you paid for it.
I spent $2,500 for Mayo to do mine. The basic tear down and re-ssembly is favorably cheap (under or at $1K) if you drop the trans off.
1981 911SC Targa
Old 06-24-2014, 12:36 PM
My 74 with 84,000 miles and a stock short shift performs just OK until I downshift from 5th to 4th. Sounds like it’s trying to go into reverse. I’ve seen the lockout in action and it blocks the lever from going into reverse from 5th. Pardon what most will consider a dumb question but is the same synchronizer take care of going into 5th from 4th and then back to 4th? The coupler does not appear to have need bushings but could I just have a coupler adjustment issue?
Thanks for your help.
Old 09-22-2024, 08:27 AM
The 9 Store
Funny, there's a shop in Houston that sends us engines and transmissions to rebuild. They don't have anyone in house that knows the air cooled stuff and they can still make a profit shipping it to us to do the work.
All used parts sold as is.
Old 09-22-2024, 09:02 AM
I can confirm!
The 915 on my 84 Targa started popping out of first which led to me pulling the engine and transmission from the car. I sent the transmission out for rebuild while I work on refreshing the engine.
https://forums.pelicanparts.com/porsche-911-technical-forum/1153485-pulled-engine-my-84-targa-now-fun-begins.html
Old 09-22-2024, 09:47 AM
gearhead
It’s a ten year old thread.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 09-22-2024, 11:25 AM
The 9 Store
LOL. Right
Old 09-22-2024, 11:36 AM
This is almost certainly incorrect adjustment of the coupler. I've had this problem. The solution is to lengthen the linkage by slacking the bolt under the lid behind the seats and pulling back GENTLY on the gearlever. Before you loosen the bolt put tape on the shaft so that you know where you started from. You are looking to lengthen the shaft by only around 1mm. Tighten bolt and retest. Continue doing this as necessary. DO NOT rotate the shaft or else you will lose sideways adjustment.
Roy
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 09-23-2024, 07:37 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Perfectly valid question to ask. No, 5th gear and 4th gear do not have related synchronization
The shared aspect of synchronization is only the sliding engagement sleeve that is shared by “paired” vertical gears. What I mean by “paired” is in relation to the shifter pattern
1 3 5
2 4 R
1st and 2nd share an engagement sleeve
3rd and 4th share an engagement sleeve
5th and reverse share an engagement sleeve
But their actual synchronizer assemblies are separate and operated by the respective side of the sleeve for each gear. So the actual synchro operation for the paired gears is not at all shared. BUT, those paired gears are married from a shifting standpoint. Married in the sense that they both are operated by the same shift fork inside the transmission. Which means the adjustment of the actual gear shift lever itself, in a forward or rearward direction of adjustment, affects both of those gears
Kevin L
'86 Carrera "Larry"
Old 09-25-2024, 09:58 AM
I did what Roy suggested but before I realized I had replies to my question. New to the site and expected I’d get notified about a reply. By lengthening the rod did you mean the distance between the collar bolts and the coupler? Hope so since that’s what I did. But I increased that distance more than an inch just to get the shifter perpendicular. Not sure how I screwed that up because before I touched anything the shifter was perpendicular and the collar bolts were within a half inch of the coupler. But I was finally able to shift into all the gears. I’m probably really screwed but won’t know til I drive the car. I’m in the middle of replacing the alternator.
The explanation on synchronizers from my Frankfort neighbor is a real education. So I’m guessing I could have a 5th to 4th synchronizer problem. Right? I read that I should eliminate some of the simpler steps first such as checking connections and grounds and the shifter and coupler bushings. I’ve ordered a new cable. Did that because my clutch is hard to push to the floor and the cable is adjusted to the very end. Do those to facts tell me anything about the condition of my clutch?
Please be patient with me. I bought this 911 because 55 years ago I owned a 69T. Sold it when duty called. Once you’ve owned a 911 you never forget. I’m trying to test the proposition you’re never to old to learn.
Ron from IN.
Old 09-26-2024, 07:23 AM
Schulisco's Avatar
Had exactly the same issue. The issue is a misadjusted shifting linkage. The shift lever is adjusted too right and too way in front direction. Make a complete readjustment of your shifting linkage and make sure that all plastic bushings are still ok. If not, replace _all_ bad ones at first (on both shift lever and shift coupler). Then make a basic adjustment like shown in this video:
https://www.youtube.com/watch?v=b3nPONBAaZM
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 09-26-2024, 08:24 AM
Thank you. I’ll watch the video and start over after I replace my cable.
Thanks again.
Old 09-26-2024, 09:53 AM
Tags
915 transimission 911 , gearshift , transmission
