too much rust (torsion bar)
My rear torsion bar is rusty. I've used a wire brush to scrub off some of it, but there is still plenty more. What do you think?
![]() My first thought is to clean it up a little bit more, then paint it with a rust protection paint. |
cycling has-been
That looks borderline between tossing or refinshing. Your reference to 'late apexing' in you handle suggests that you use your car for purposes other than commuting, groceries, and cars & coffee.
If it were me and I depended on these parts on the track, I'd replace. You can also re-use it and wait for a FS ad for the bars that you need. Who knows, maybe even upgrade/upsize while you're in there. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Been here a while
I''ve got a pair of 31mm hollow tarret bars that were used once, literally, before the car was swapped over to coil-overs, email me, and I'll send you some photos.
This is a 31mm hollow bar. The car is used only for club racing. I haven't taken the one out from the other side yet.
I have 23mm front, 31mm rear. If I replace, what would be the upgrade? Last edited by L8apex32; 07-15-2014 at 07:30 AM.. Reason: left out upgrade question |
I wouldn't get aggressive with its surface. I'd just oil it
I don't know about torsion bars but I have seen more than one guy with good intentions sand blast a set of coil springs- inadvertently relieving them of their tension |
And you have to remember the torsion is on the outside of the bar.
Bruce |
| Tags |
| rust , torsion bar |
