Eva
911SauCy's Avatar
Originally Posted by jarrodblake View Post
but other then dirt its really clean.
[/IMG]
This and the complaining about the bondo...LOL
Sub'd for comedic relief and epic huevos for taking on a project of this magnitude.
Godspeed
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 08-13-2014, 08:46 AM
912 Geek
Definitely LWB; someone may have put earlier doors on it (vent windows, door handles) years ago. Back then we did a lot of crazy stuff!
Old 08-13-2014, 10:07 AM
jittsl's Avatar
"Other than the dirt it's really clean"
And
Other than the rust it's really solid.
Laurence
1998 Specbox racer / 1998 Boxster / 1984 RSR tribute
1970 911E Coupe / 1970 911E "speedster" / 1969 912 Targa
1963 356B T6 Coupe / 1962 356B T6 Cabriolet
Current projects - 1955 356 pre-a Speedster / 1964 356C
Old 08-13-2014, 11:20 AM
Good luck in this project.
There are some guys around here who have breathed life into cars that I was amazed by: this one would take the cake.
As a 'side' I must suggest you stay air-cooled. Some of the beauty behind these cars is the incredible sound they make.
When you consider bringing a car like this back to life, try to go period correct; putting a modern-ish power plant in this car will stand out (in a sore thumb sort of way, in my opinion). ...but then again it's your car/project.
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html
Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things.
Old 08-13-2014, 12:17 PM
Jarrod,
I hope you are, or know, a very good fabricator/welder. That's a lot of work there.
Bob B
Old 08-13-2014, 12:38 PM
jarrodblake's Avatar
Not much Progress has been made, still striping it down.
I removed the passenger seat its in rather good condition.
Rear seat pans look good.
The rocker panels are surprisingly solid.
Old 08-20-2014, 10:08 PM
Removing the rocker trim
I maybe able to reuse the fabric and make a new door card? Also anyone know what I can find a reproduction of this material?
Old 08-20-2014, 10:09 PM
Glass removal has been supper easy, well other then the rear passenger wing glass, but more on that later.
Old 08-20-2014, 10:10 PM
Started driver door break down I will need to find a new wing vent glass.
Moving on to whats left of the driver seat.
I found the glove box trim plate under the driver seat.
The amount of rust I have removed from this car is astonishing.
I also aired up the driver front tire and it sprung a leak, there must have been a gallon of water in there.
Is it safe to store glass like this?
Old 08-20-2014, 10:11 PM
Made some room for more parts.
Removed the dash pad and found this.
Removed the hood
Old 08-20-2014, 10:12 PM
Finished the driver door. Now I need to buy the correct triple square bit set to remove the doors.
Dissembled and removed the duck tail and proceeded to install it on my other car.
looks like it had gold lettering.
I tried cleaning them up, but it looks like they tried to sand then down before painting them. The 911E does not look to bad however the P.O. had been sanded through in spots.
Removed the fenders.
Where I stopped tonight.
Hopefully this weekend I will finish striping it down. Then I will start building a car rotisserie for it, before I start media blasting it.
Old 08-20-2014, 10:17 PM
D@vid's Avatar
Quite an impressive undertaking. I would be really impressed if this poor car can be resurrected. I wish you all the luck (and stamina) in the world Jarrod.
1973 2.4 MFI
bone-stock 911T
Old 08-21-2014, 03:10 AM
wayner's Avatar
Awesome!
You might need this:
Here is the site for reference. I believe that once you find the parts you want, you can look them up and order them form our host.
http://www.restoration-design.com/mm5/merchant.mvc?Screen=CTGY&Category_Code=911-CHA
SOLD - 914 wide body hot rod
Old 08-21-2014, 04:24 AM
I am always amazed to see that some of you guys have the courage, patience and skills to take on a project like this. I hope you follow through and post your progress for us to follow.
Juergen
'86 Carrera Cabriolet Grand Prix White
'09 VW Beetle Convertible
‘24 Audi Q8 etron
Old 08-21-2014, 06:44 AM
For now, don't unbolt the door hinges-- just pull the pins out. You'll want to preserve as much of the original panel fit (did I just say that?) as possible.
Old 08-21-2014, 07:20 AM
Dublinoh's Avatar
Would it be wise to weld in some cross supports as well?
Good luck with the project!
Old 08-21-2014, 07:36 AM
Andy Bullen
andybullen's Avatar
Send a message via AIM to andybullen Send a message via Skype™ to andybullen
Great to see the effort being put in to something
many would consider too far gone. If you decide to keep it all
original, it could be quite profitable considering you're doing all
the metal fab....
76 912E - Grocery Getter
04 Toyota TacomaTRD - Beater Truck
08 Honda OdysseyEXL - Family Hauler
Old 08-21-2014, 07:58 AM
78-911SC's Avatar
Love the porcelain passenger seat. Ha Great progress and great documentation.
PJ
78 911sc Targa
70 911T
Old 08-21-2014, 08:31 AM
