gliding_serpent's Avatar
Originally Posted by outlaw911 View Post
By report- great (car is still "across the pond" in the UK).
Right. My car was only 30 min away last winter/spring/summer, but it was hard to be away from it. Must be tough to be across the sea.
Do you know the piston compression? Same goes for the maf. Looks like it is wired into the harness. I wonder how the system uses that info. I know Sal's system involves a completely reprogrammed code so that the MAF can "talk" to the DME. Your MDS system intrigues me, and i admit not knowing much of how they work.
1997 BMW M3 (race car) with S54 engine swap "The Rocket"
1984 Porsche 911 3.4 Carrera
1973 BMW 2002Tii
2016 Ford Focus RS
Old 12-04-2015, 05:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #161 (permalink)
Maf?
I don't know the details of the MAF
This is the system that was installed:
FVD LB1 performance kit "Race" w sport catalytic
http://www.fvd.de/us/en/Porsche-0/-/-/-/item/item_details/VID_3619694-VCD_82902899-gid_37-sort_4-display_50-item_FVD11007/Tuning_-_Engine_-_Air_Intake_-_Power-Flow-Kits_FVD11007_LB1_performance_kit_`Race`_with_spor tcatalytic_911_84-89.html
Old 12-06-2015, 04:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #162 (permalink)
Cool. I am quite ignorant as to products available across the pond. Being in canada, the current exchange rates may be more favorable vs the us dollar.
I will have my MAF by christmas. It does not come with a cat, but is paired with modern injectors.
Will be keen to see your finished engine output. Great build. Good luck.
Old 12-07-2015, 03:55 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #163 (permalink)
Home sweet home...
Old 04-18-2016, 03:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #164 (permalink)
Typically there is a very small circuit embedded in the harness of the MAF converting the MAF output into a signal the original barn door meter would deliver. This way it is plug-and-play. Quite a few guys over here have done that conversion and I was thinking about it (but pulled the trigger on a 964 motor in the mean time)
Old 04-19-2016, 12:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #165 (permalink)
sp_cs's Avatar
That looks stunning! You must be delighted with it?
Shirish
1987 Carrera, Granite Green
Old 04-21-2016, 10:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #166 (permalink)
Bill Douglas's Avatar
Decidedly funky!
Old 04-21-2016, 10:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #167 (permalink)
Agreed, it looks great! Enjoy it!
1973 BMW 2002Tii
2016 Ford Focus RS
Old 04-22-2016, 04:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #168 (permalink)
Rmmmmm rrrrrrrrmmmmm
Couldn't be happier
Old 04-22-2016, 05:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #169 (permalink)
Overall very happy with the car one year in.
Some persistent gremlins however remain however: most significant there is a steering wheel "shake" that is worst around 60-70 mph. Car does not "pull" left or right. I initially thought it was just a tire out of balance- but had the tires balanced and it was better- but still there- seems to be worse on roads with "seams" (you know bump, bump, bump)...?????? Any ideas? Car does have mild bump steer since being lowered...I'm planning to have a "bump steer" kit installed but really know nothing about them.
The other issue- tires. I went with 7 and 9 x16 minilites thinking there would be more tire choices than at 15. Car currently has Kuhmo Ecsta v700 225/45 front and 265/45 rears- I like them a lot (good grip, not too noisy and look right) but they're getting worn. I looked for a replacement set but could only find them on a Japanese website.
ã‚¯ãƒ ãƒ›ã‚¿ã‚¤ãƒ¤ã‚¸ãƒ£ãƒ‘ãƒ³æ ªå¼ä¼šç¤¾ - タイヤラインナップ - ECSTA V700
Plan B would be Bridgestone Potenza Re11:225/50 16 front and 245/45 16 rear
(I know some people run 205 in the front but they don't seem to be available in the re11's and I'm trying to avoid mixing). So I guess my questions; are the Kuhmo's still available? and would 225/50 be right for the 7's and 245/45 right for the 9's?
Old 06-05-2017, 12:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #170 (permalink)
Bump steer kit is a must on any car lowered.
I know this might sound stupidly basic, but try swapping the front wheels (if the tires are not directional). I've had two cars in the past with alignment and/or shimmy and a simple wheel swap did the trick. Also you may want to consider your rotors. Even the slightest warping can cause your steering wheel to shake, the frequency may be most evident at 60-70 mph.
Just my input. I'm no expert and others will likely chime in to offer their advice.
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 06-05-2017, 04:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #171 (permalink)
Elombard's Avatar
That sounds like a separated belt, usually you can see it by jacking the front wheel off the ground and spinning. You can see the "lump" roll around. I have seen them balance out but still have the lump.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 06-05-2017, 04:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #172 (permalink)
Bill Verburg's Avatar
The universe of reasonable sizes in any particular size 15-17 is small no matter which wheel diameter is chosen
Bill Verburg
Old 06-05-2017, 04:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #173 (permalink)
Occasional User
Cook&Dunning's Avatar
Congrats on a beautiful car. Amazing. Great plan and result. I am sure you can resolve the tire issue.
Vince
2015 Boxster S, Black & Black
1989 Carrera Silver Coupe, Silk Grey - sold
2009 Cayman S White, Full Cocoa - sold
1972 911E Silver Coupe, Pepita & Black - sold
Old 06-05-2017, 04:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #174 (permalink)
MattNZ
Are the wheels correctly centre bore located? If not, no amount of balancing will have any effect.
Old 06-06-2017, 01:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #175 (permalink)
moparrob's Avatar
You are definitely on the right track by setting the right height correctly, installing the bump steer kit and I would add a four wheel alignment while you're at it.
Old 06-06-2017, 02:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #176 (permalink)
Help
When I backdated the car I choose to go 16x7 and 16x9 inch because I thought there would be more street tire choices at 16 than 15. My current tires (Kumho Ecsta v700 225/45R16 front and 265/45R16 rears) have been discontinued and my second choice (Bridgestone Potenza re11's 225 50 16 and 245 45 16) seem to be no longer available either?!?!
Toyo T1Rs?
Any other options?
(I wish now I had gone 15 inch with TB15s- there expensive but everyone seems to agree great tires and at least they're still making them)
Old 11-09-2017, 04:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #177 (permalink)
lateapex911's Avatar
Hey Outlaw911....I'll join the crowd with a pat on the back for your most excellent taste in colors and interiors. Did you resolve the shimmy? If not, do you notice it getting worse and beter as you drive? Changing around long corners? If so, it's the tires. Mine had a similar ssue and it was a minor and impossible to see belt issue. 911 Steering is Soooo sensitive, it doesn't take much. New tires did the trick for me.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 11-09-2017, 11:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #178 (permalink)
Pelican Parts Vendor
BRAIDusa's Avatar
Yes, 16" are tricky. I'm tempted by these for our UR Quattro rally tribute:
https://www.tirerack.com/tires/tires.jsp?tireMake=Pirelli&tireModel=P+Zero+Trofeo+R
There are also these from Pirelli but probably too big in 16" sizes.
https://www.pirelli.com/tires/en-us/motorsport/all-tires/products-sheet/p7-corsa-classic
I'm running Toyo RA1 on my street Quattro. I'd run the T1R but I don't like the tread design.
Other options: https://www.tirerack.com/tires/TireSearchResults.jsp?zip-code=&frontWidth=225/&frontRatio=50&frontDiameter=16&rearWidth=245/&rearRatio=45&rearDiameter=16
Help
Toyo T1Rs?
Any other options?
Paul Eddleston
BRAID Wheels USA
Team Illuminata Motorsport
Old 11-10-2017, 06:22 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #179 (permalink)
Midwest R Gruppe
t6dpilot's Avatar
Cool car. Nicely done. Where in IL are you? I would for sure go with 15's. They look so much better than 16's on early cars. Those Pack Racing Minilites just don't look right in 16". There are good tire choices too, but not as good as 16". Avon makes a great tire that have the prefect period look.
Scott
69E Coupe 2.2S LtWt
73.5T Coupe
Old 11-10-2017, 06:58 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #180 (permalink)
