Fuel door cable on 1988 911 cabriolet
I am getting back into the 911 world with a inherited '88. This replaced one I had before but lost it to storm damage - tree fell on it.
Now for the new project - the first of many inquiries - The fuel door on this cab would not open as the pull handle needs a key and the family I got the car from had no idea where the key might be. I have pulled things apart only to find there is no cable attached to the fuel door catch. Now I need to remove the handle and get it replaced/re-keyed/ repaired. Can anyone tell me how to remove the locking cable pull without tearing things up? I have enough work to bring this project to street worthy condition without adding to the mess. (Yes, it is a mess - disassembled and forgotten for 6-8 years before I talked them out of it with the promise that I would give the widow a ride once it is back together). Any assistance in getting this issue solved will be greatly appreciated.
Derby City, Louisville, KY 1988 911 Cabriolet Project 2013 Mini Cooper (Wife) 2020 Mercedes GLA 1984 Citroen 2CV |
I may be mistaken, but I've never seen a fuel door pull with a lock.
The fuel door release should be located above the AC vent by the driver's door. The front trunk pull which is located below the dahs should have a lock in it. this lock should operate using the same key as the doors and ignition, provided you are not using the valet key. |
Trunk release is keyed as 76FJ55 said. Try the key.
As for the Fuel door pull which is non-locking but can be stubborn to open due to cable being stretched, out of adjustment or a bit rusty stuck from no use and/or needs guide tube lubricant. Try pushing down on the fuel door while pulling the knob could get it to release open. So just to be clear of which pull handle….
