Can you change oil cooler fittings?
Hi,
I found a front mount oil cooler with 12-an fittings. Can I take it to a rad shop and have them weld 16-an fittings and not be detrimental the the internal oil flow of the cooler? Thanks for any information. |
I've seen different fittings welded on coolers but it depends on the cooler and what the welder has to work with.
Kurt |
