burning rubber smell - not good - 87 911 Carrera
I let my wife borrow my car last week (first mistake). My car is an 87 911 Carrera 3.2 coupe. Wife did not drive it too far, but she admits that she left the parking brake on for at least one segment of the trip. For the next few days, I could smell burning rubber any time I drove the car, even short distances with minimal braking. It is now a week later and I still get a waft of burning rubber when I drive my car. I'm assuming this is related to the parking brake issue because I never noticed it prior. Anybody have thoughts on why I would still be smelling it a week later? Thanks in advance.
Old 03-30-2015, 11:34 AM
pete3799's Avatar
Doubt it is the brakes you're smelling......a shorted wire perhaps. All electrical components working? Lights, fans, etc.?
Pete
79 911SC RoW
Old 03-30-2015, 11:42 AM
twistoffat's Avatar
Unless she fried your clutch by driving with the handbrake on.
Old 03-30-2015, 11:50 AM
as far as i can tell, all lights, fans, electrical systems work. it is possible that she fried the clutch by driving with the parking brake on?
Old 03-30-2015, 12:03 PM
twistoffat's Avatar
Yep, You can test it by starting off in second gear with moderate revs. If the clutch is okay it should stall the engine. If its not okay it will slip and youŽll get the burning rubber smell
Old 03-30-2015, 12:34 PM
I would be very surprised if she fried your clutch by leaving on the emergency brake.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 03-30-2015, 01:01 PM
scarceller's Avatar
Have you been using the heat system in the cabin? If so are both LHS and RHS footwell blowers working?
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 03-30-2015, 01:24 PM
87 - 911
Immediately after a taking a drive, get out and put your hand on the center of each of the wheel rims, if a brake is hanging up that rim will be hotter than the others.
Having said that the wheel would have to get awful freakin hot to create a burning rubber smell. More likely an electrical issue and since some of the circuits are non fused you'd best get it sorted before long.
Old 03-30-2015, 03:53 PM
Do you also smell burning brakes or just the rubber smell? because leaving the e brake on would certainly leave a lingering smell. I would say thats certainly where the smell came from. Buning clucth makes the same smell as the brakes so thats certainly a possibility. But It would be more because of poor driving than leaving the brake on
Old 03-30-2015, 04:08 PM
83 911 Production Cab #10
JJ 911SC's Avatar
As long you are not smelling "Burning Toast" you should be OK
As for the car symptom, not related to the Emergency Brake for sure if it was a small distance.
Who Will Live... Will See
Old 03-30-2015, 04:21 PM
MBAtarga's Avatar
I had a similar issue with what I thought was an electrical problem as the odor was appearing under the dash and I "traced" it to near the fuse panel by smell. I further narrowed it down to the driver front caliper. It was sticking, hence the small was not electrical but rather VERY hot brake pads.
Mark
'83 SC Targa - since 5/5/2001
Old 03-30-2015, 04:43 PM
Tags
brake , parking brake
