burning rubber smell - not good - 87 911 Carrera
I let my wife borrow my car last week (first mistake). My car is an 87 911 Carrera 3.2 coupe. Wife did not drive it too far, but she admits that she left the parking brake on for at least one segment of the trip. For the next few days, I could smell burning rubber any time I drove the car, even short distances with minimal braking. It is now a week later and I still get a waft of burning rubber when I drive my car. I'm assuming this is related to the parking brake issue because I never noticed it prior. Anybody have thoughts on why I would still be smelling it a week later? Thanks in advance.
Doubt it is the brakes you're smelling......a shorted wire perhaps. All electrical components working? Lights, fans, etc.?
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Unless she fried your clutch by driving with the handbrake on.
as far as i can tell, all lights, fans, electrical systems work. it is possible that she fried the clutch by driving with the parking brake on?
Yep, You can test it by starting off in second gear with moderate revs. If the clutch is okay it should stall the engine. If its not okay it will slip and youŽll get the burning rubber smell
I would be very surprised if she fried your clutch by leaving on the emergency brake.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
Have you been using the heat system in the cabin? If so are both LHS and RHS footwell blowers working?
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
87 - 911
Immediately after a taking a drive, get out and put your hand on the center of each of the wheel rims, if a brake is hanging up that rim will be hotter than the others.
Having said that the wheel would have to get awful freakin hot to create a burning rubber smell. More likely an electrical issue and since some of the circuits are non fused you'd best get it sorted before long. |
Do you also smell burning brakes or just the rubber smell? because leaving the e brake on would certainly leave a lingering smell. I would say thats certainly where the smell came from. Buning clucth makes the same smell as the brakes so thats certainly a possibility. But It would be more because of poor driving than leaving the brake on
82 SC , 72 914 |
83 911 Production Cab #10
As long you are not smelling "Burning Toast" you should be OK
![]() ![]() ![]() As for the car symptom, not related to the Emergency Brake for sure if it was a small distance.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
I had a similar issue with what I thought was an electrical problem as the odor was appearing under the dash and I "traced" it to near the fuse panel by smell. I further narrowed it down to the driver front caliper. It was sticking, hence the small was not electrical but rather VERY hot brake pads.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
| Tags |
| brake , parking brake |
