LinkBack | Thread Tools |
You say that the roll pin must be installed with the slit facing away from the center of the shock. Is this the "3 o'clock" position?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
The slit needs to be on the spindle side of the shock. The o'clock position will be different depending on which side of the car you're working on
- Casey |
The slit will face inward, away from the shock shaft. Stick a punch in the hole first to be sure the notch in the shaft is going to be captured by the pin.
