Just great...
Was looking forward to a long, quiet afternoon of working on the 911 engine and have run into some bad luck that I could really use some advice about.
My car is an '86 Carrera with 62k miles on it. I have the engine out to replace fuel and vacuum lines, do the usual "while it's out" oil leak prevention stuff, etc and today pulled valve covers to adjust valves...
Yep, 3 exhaust head studs fell out. I know enough to know that repair is beyond my capabilities, so some questions:
1. Can anyone recommend a shop in the KC area who will do the work correctly and at a reasonable price?
2. What else should be done while the heads are off? Valve job and guides I assume? With my car's low miles, I wouldn't think anything else would be necessary?
3. What kind of head studs (bolts) are considered the best to use now?
Thanks in advance for any advice...off to sulk now.
Old 05-31-2015, 03:19 PM
Steel (not dilivar). Yes, do the guides.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 05-31-2015, 03:33 PM
RETIRED
Joe Bob's Avatar
I used Raceware.....
2012 ML350 3.0 Turbo Diesel
Old 05-31-2015, 05:05 PM
I've had work done at RennsportKC they have always done a great job.
Old 05-31-2015, 05:19 PM
Project Addicted
Your looking at a top end rework, with heads rebuilt.
New steel lower studs are fine for a stock street engine tho the racy bits are gorgeous.
Replace the 2 speed sensors on the flywheel and the cylinder head sensor on the drivers side head.
Good luck!
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 05-31-2015, 05:59 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Fell out? you mean they walked out with the nut/barrel nuts or literally dropped out?
'85 Carrera Targa
PCA/POC
Old 05-31-2015, 06:13 PM
Karl at RennsportKC took good care of my car. I also recommend talking to them.
RennsportKC
1979 911 sc coupe
Old 05-31-2015, 06:14 PM
VW_NUTT's Avatar
This is not a hard job. I just completed my rebuild. Engine runs great. Get Waynes book and buy some tools. You will save thousands and have the satisfaction of doing it yourself. Every step is covered in the book from removal to break in. Follow it and you will be back on the road in a several weeks. Take lots of pictures to look back on when putting things back together. And get a good torque wrench! And go from this.
to this
1984 Carrera
1985 Vanagon Westfalia
2009 Audi A3
2015 VW Jetta
2016 Sprinter
Old 05-31-2015, 06:23 PM
Aaron at BHR. Highly recommended.
Don
_________
72 911T Sepia 2.4
08 Audi A6 quattro 3.2
03 Toyota Tundra
Old 05-31-2015, 08:40 PM
Chain fence eating turbo
No need to tear down the low end, although it's really not much to it.
Replace the rod bolts with ARP. You cannot skimp on this.
993TT head studs are Divalar and are really tough. I have them for years running lots of boost no problem..Henry Schmidt makes good ones too.
Old 05-31-2015, 08:46 PM
Talked to Karl and it looks like he's going to take care of me. Thanks all for the help!
Old 06-01-2015, 07:59 AM
Use Supertec studs.
1972 911T/S MFI Survivor
Old 06-01-2015, 12:26 PM
