I suspected it may be wrong, thanks for verifying it.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
83 911 Production Cab #10
It does but for the 84-85 (pg 970-26) and 86-87 (pg 970-28) show pin 21 & 11 going to the tach, very strange.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Brew Master
I guess the question remains, what could I have unhooked in the engine compartment that would effect tach signal? Anything? It' seems odd that my tach stopped working when it worked when I pulled it in the shop 3 weeks ago to drop the engine.
Did you do a continuity check from DME connector pin 21 to the back of the the tach?
Brew Master
I'm about to jump in it, go get a coffee and then do some digging. When I get back I'm going to pull the tach and do some checks. I'll let you know what I find. I just have a feeling I'm chasing my tail since it stopped working when I pulled the engine and nothing inside the car itself was touched.
The tach connects on a flat 4 wire connector.in the trunk above the gas tank , Doesn't necessarily have 4 wires. 2 small black wires, 1 black, purple stripe tach drive wire and a yellow wire.
There is nothing to drive the tach in the engine compartment of a Carreras. Bruce |
Brew Master
UPDATE:
No continuity between Pin 21 black/purple wire at tach Pin 11 has continuity to what appears to be a black wire next to the black purple in the 6 pin that goes to the back of the tach. Last edited by cabmandone; 06-20-2015 at 05:14 AM.. |
Brew Master
It would seem there would have to be a wire from the coil or the injectors telling the DME what rate they are firing at. |
So you got continuity between pin 11 & the BLK on the back of tack which is good.
Since you got no continuity between pin 21 & the BLK/VIO (purple), you will need to trace that wire. If you can find the connector that Flat6pac mentioned, re-do the continuity check from that connector to the back of the tach one way and to pin 21 the other way.
The high voltage pulses (several hundred volts) that are fed to and drive the coil are developed INSIDE the DME using speed sensor/index sensor etc. The tach pulses are derived from that circuit and sent from the DME directly to the tach. Obviously, if the car runs, the speed and index sensor work AOK. Older cars with conventional ignition use the points or an output from the CDI unit to drive the tach.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 06-20-2015 at 07:15 AM.. |
The black wire on the 4 wire connector I mentioned, there is 2. One runs to the up shift light and the other runs to the fuel pump relay under the seat. I think the yellow wire shuts down the A/C under hard acceleration.
Bruce |
Actually the yellow wire compensates the idle speed up a bit when AC compressor is energized so the engine runs smooth at idle.
Brew Master
I tested this harness to the DME and got continuity on the larger black/violet wire but not from the smaller to the tach. It would seem I have a bad wire. So should I run a small from the larger black/violet up to the terminal and the tach and test?
Brew Master
Oh good grief, now it shows continuity when I plug the connector in. I'm going to fire and test.
Aaaaaaaaaaaaaand we have tach again. How flaky. |
Good. its 12:00 somewhere in the world so have one or two...
We've all learned some things today..
Bruce |
Brew Master
Thanks for your help Bruce, JJ and others. I really appreciate it. I'm on to a beer or 3 but before I do I have to pull the valve covers on the right side. I have a clicking noise coming from the #6 rocker on the top side (used a stethoscope and could hear louder click at that rocker location on the valve cover) I'm going to verify the valve is adjusted right.
Brew Master
Oh just one can't hurt
Brew Master
See, I should have known better. Things were out of balance in my pic. Thanks for fixing that!
