Should I/How to - Clean inside splines of Torsion Tube
Took my rear torsion bars out - if I look inside the tube, it looks pretty clean, but at the splines looks like some gunk... any reason to try and clean it up? how would I even get in there to clean it without messing things up?
1986 Carrera 3.2 Coupe in Grand Prix White IG: @c.cal.porsche |
Bottle brush on the end of a long dowel?
I would not focus on cleaning as much as I would getting enough fresh grease on the torsion bar. |
PCA Member since 1988
Don't worry about it.
I would be a LOT more concerned about the outboard end of the torsion tube. It looks like the cup has rust holes in it.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
I think what you might have thought was rust was just dirt/rubber... cleaned it up a bit.. still looks like some brown stuff, but doesn't seem like rust...
Amazon sells a 3” diameter extra long “bottle” brush…cheap
That looks better.
I made a giant "Swab". I just took a white towel and taped it on to a long 1" dowel. Swab, change the towel, repeat. I think I sprayed some brake cleaner on it. It took several iterations, but it worked well.
Robert Callaway PCA | Early S Registry | R Gruppe 1970 T Coupe, 1990 C2 Coupe, 2007 Cayman S 1962 S90 Coupe - Gone, but never forgotten... 1985 Targa - A distant memory... |
Registered Minimalist
Friend had me take over his project car. Torsion bars were sticking out of both sides like 30mm. Pulled them and found sand and grit in the inner splines. Used a brass brush on a dowel to clean and then vacuum out all the particles.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
A little heat on the center of the tube helps if it’s not covered with chipgaurd.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!! |
