I used the expandable tubing on my wiring as well. Though to terminate the ends I used shrink tube and the end result looks really nice without having to use tape.
1982 911 Targa, 3.0L ROW with Webers
Old 12-12-2019, 03:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #681 (permalink)
MFX MFX is offline
That looks great. I will be using heat shrink on the ends. I am just using the tape on the splices, where heat shrink doesn't do as well
See my 2.8RSR build on YouTube 'Home Built by Jeff'
http://youtube.com/homebuiltbyjeff
http://forums.pelicanparts.com/porsche-911-technical-forum/889676-home-built-hot-rod.html#post8868732
Old 12-12-2019, 04:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #682 (permalink)
Originally Posted by MFX View Post
I have been dying to put my shiny new ITB's onto the engine for a while and they look so good.
Jeff - I had a dumb question about this episode - when installing your alternator, there does not appear to the diverter vanes on the back of the alternator for air flow. Maybe this is something later engines don't have (I think yours is a later engine) than my early 2.0 - but I thought I'd mention it in case it was originally missing or something. Called a hub extension 911-106-033. Maybe I just didn't see it when you were mounting the alternator.
Cheers!
Keith - Calgary
1969 912R (911 engine) - Blutorange
Old 12-13-2019, 08:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #683 (permalink)
MFX MFX is offline
Cheers!
Not dumb at all. A mate noticed the same thing and the dodgy engine that I got with this car didn't have it, but it does need it and I have ordered one. As it never had it I didn't even know I was missing it.
Old 12-13-2019, 02:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #684 (permalink)
MFX MFX is offline
Back into the wiring on the 911 engine and this time I tackle the connectors.
Old 12-17-2019, 12:11 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #685 (permalink)
MFX MFX is offline
This week I finally fit the fan belt and finish most of the wiring on the engine.
Old 01-01-2020, 01:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #686 (permalink)
MFX MFX is offline
Many of you have seen a lot of my garage in my videos, but in this video I give you a full tour, and you may even get some hints about upcoming videos.
Old 01-18-2020, 12:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #687 (permalink)
al lkosmal's Avatar
That's a shop
Jeff,
Thanks for the tour. Now that looks like a good, usable work space....that actually gets used on a regular basis.....
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 01-18-2020, 10:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #688 (permalink)
Hopefully you've not been affected by the bush fires
Old 01-18-2020, 11:29 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #689 (permalink)
MFX MFX is offline
Originally Posted by al lkosmal View Post
Jeff,
regards,
al
Thanks Al. It keeps evolving, as I gradually work out what works for me.
I did a video about the fires a week or so ago on my channel, it is worth a look
Old 01-18-2020, 11:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #690 (permalink)
MFX MFX is offline
This week I was back working on the 911, but I lost all of the actual footage of the day. So here is a summary.
Old 01-21-2020, 01:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #691 (permalink)
Jeff, you may already know this, but there are programs that can recover files from a corrupted or damaged card. I work in photo/video and they've saved my ass a time or two. I believe the one I have is called "cardrescue." Hope that helps and keep up the great work!
Old 01-21-2020, 09:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #692 (permalink)
MFX MFX is offline
Thanks. That is something I will keep in mind for the future, although I really hope I don't need it
Old 01-21-2020, 03:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #693 (permalink)
MFX MFX is offline
Back to work on Harry this week and I run the car side of the loom and mount the ECU.
Old 02-12-2020, 01:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #694 (permalink)
Counterclockwise?
Jeff, giving your cars names is a little …..weird. lol
Rod
1986 Carrera
2001 996TT
Old 02-12-2020, 06:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #695 (permalink)
MFX MFX is offline
Just like me
Old 02-12-2020, 05:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #696 (permalink)
I was going to go the same direction as you with air cleaner "windows" but i,m running Webers and was worried about the carbs backfiring. The only solution I could come up with was to possibly use toughened glass .
In the end i just machined the middle strips out of my K&N cover and added plastic PORSCHE
lettering from Ali Express !
Old 02-13-2020, 07:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #697 (permalink)
safe's Avatar
Plastic (Lexan whatever) shouldn't be a problem.
Porsche used plastic air boxes, early cars had metal.
Magnus
Old 02-14-2020, 01:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #698 (permalink)
MFX MFX is offline
I am not too concerned with my ITB's back firing (or pre-firing to be more precise), and at worst if the perspex I have used proves to be a issue, it is simple enough to replace them with something else.
Old 02-14-2020, 02:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #699 (permalink)
MFX MFX is offline
This week I finish up the engine bay portion of the wiring and set up the dead head fuel system on Harry.
Old 02-19-2020, 02:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #700 (permalink)
