Dear PO, I wish you hadn't...(advise needed)
Dear Previous owner,
I wish you had not cut slits in the firewall to fit 50 Lbs of ****ty speakers in this car... I really dont like finding your old issues...
Anyways, I need you guys advise. As you can see in the pictures the previous owner of my car cut slits in the firewall/parcel shelf and pounded the hell out of the sheet metal to allow room for bigger speakers... I found this when stripping the interior, not fun. It was sealed with a black silicone which I have removed. My question is this.
Should I:
A) POR 15 the slits to prevent rust and leave them? (obviously the quickest, not really leaning towards this.)
B) Try to pound the sheetmetal to the original state and find a welder to quickly weld the pieces back together.
C) Fill in your answer here...
I am by no means an expert here. Just want to have a bad ass fun 911 to take to the track and drive around the mountains...
Thanks for the help!
Old 11-29-2015, 03:57 PM
Reiver
Reiver's Avatar
I'd pound them level and weld them up...they could be sealed in another fashion but a nice weld would make me happy.
Having a way for exhaust fumes to enter the cabin (even if remote) is just not a good idea.
The PO wasn't overly bright.
De Oppresso Liber
Strength and Honor 5th Legion
Old 11-29-2015, 04:06 PM
Tired Member
DaddyGlenn's Avatar
Shouldn't be too difficult to cut out the whole panel and weld in one cut from a junk yard car.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 11-29-2015, 04:11 PM
Reiver
Reiver's Avatar
The title of your thread would make a good open 'blog',,,as soon as I read that I thought about my own PO issues.
De Oppresso Liber
Old 11-29-2015, 04:32 PM
Your right! I am sure I am not the only one cursing my PO!
Old 11-29-2015, 04:43 PM
I think I may try this and see how it works... Seems the least obtrusive. Unless there is a better Idea that also doesn't involve mass anxiety....
Old 11-29-2015, 04:45 PM
I thought of this... scariest option I could think of... Funny I was reading through your thread the other day! I got all excited to see you replacing the dash and it looking so good.. I am trying to DIY my dash now... When I am finished I will post results. Yours looks great! Love the yellow plad seat inserts by the way!
Old 11-29-2015, 04:49 PM
non-whiner
mreid's Avatar
Disconnect your ignition electronics if you have them prior to welding. If you have an msd, it 100% will fail. DMEs, etc may vary.
"Too much is just enough."
Old 11-29-2015, 05:14 PM
sugarwood's Avatar
My PO was a mixed bag:
1) K&N cone air intake. But PO he saved the stock airbox. I have since reinstalled the stock airbox, and sold the cone.
2) Strut brace. I will remove this, sooner or later.
3) 16x9 Turbo Fuchs upgrade. Thanks PO!
4) Hacked up the rear deck to install huge speakers. But, PO saved the speaker grilles. I bought another rear deck, and reverted back to stock sized speakers.
I sold the rear shelf with big speakers. I also reverted the door speaker grilles, which PO saved.
5) B&B stainless steel exhaust.
1986 Bosch Icon Wipers coupe.
Old 11-29-2015, 05:30 PM
I'm with daddyglenn on this one. Pounding has already stretched and distorted the metel. more pounding won't undo that. A nice clean panel welded in by a pro will yield the best result.
Just my opinion.
regards,
Phil
Old 11-29-2015, 06:47 PM
Just my opinion.
regards,
Phil
This is definitely the end all be all. Any idea what this might cost? Does anyone have a welder that they might recommend in the Atlanta/Alpharetta area?
I appreciate all the response. Keep 'em coming! And keep the PO stories coming!
Old 11-30-2015, 03:45 PM
Mick_D's Avatar
it'll be pricey , the panel runs about 300 bucks or so and the welding will take at least r4 hours at whatever the welder says it'll cost. But it's the only way to fix this issue. If you can take out the glass it will save time and labor.
Old 11-30-2015, 04:12 PM
CatsEyes's Avatar
I just thought I'd add my signature to this discussion...
1980 911 SC Metallic Blue Euro spec, 'Greta'; 1986 944 Euro spec Light Bronze Metallic, 'Sabine II'
1986 944 NA Euro spec Guards Red 'Sabine I' - RIP, gone but not forgotten
'Hell is previous owners.' (anon.)
Old 12-01-2015, 03:46 PM
Tired Member
DaddyGlenn's Avatar
Thanks! When I started my project so many years ago, the thought of cutting and welding was a very scary thought. Turned out to not that big of a deal.
Glenn
Old 12-01-2015, 04:39 PM
Tired Member
DaddyGlenn's Avatar
Restoration Design has the part for $285 but if your edges are good you could probably find someone to cut one out of a junker for a lot less. Try some of the Porsche dismantlers. And I bet you could find a Pelican in the Atlanta area that would weld it up for you for very little, if anything.
Glenn
Old 12-01-2015, 05:02 PM
Chain fence eating turbo
There's something wrong with you guys.
It's covered, no one will ever see it. Geez...
Old 12-01-2015, 05:40 PM
Dial 911
A horse with no name's Avatar
Ahhhh, but You will Tippy
A quote to keep you on the right track ...."Just when you think that it is good enough - It isn't"
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 12-01-2015, 05:46 PM
Straight shooter
Lapkritis's Avatar
X2.
Grind/paint after weld. Then cover with dynamat before oem parcel shelf cover installed.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 12-01-2015, 07:08 PM
Bill Douglas's Avatar
Exactly. A bit of duct tape here and there.
Old 12-01-2015, 08:19 PM
irl irl is offline
irl's Avatar
Send a message via AIM to irl
I'd pound it back and brush some seam sealer on the slits. It's thick and will seal it right up. Carpet the top and put an engine liner on the backside.
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 12-01-2015, 08:47 PM
