J. Perrault
Suggestions for type of paint- flapper boxes ?
Flapper Boxes on the car (SC) are rotted/crispy, and is a slow boat to China getting them off. Very afraid of snapping the little studs. Its taking forever....
However, I do have a set in really decent shape to swap in, if the existing set comes off.
Whats held up for you guys through the years ?
POR15 ? Rustoleum heat temp ? Regular Rustoleum rust cap ? Doesn't matter they rust out anyway ? HAHA
Thanks !
Old 02-03-2016, 06:33 PM
Reiver
Reiver's Avatar
POR15 would be perfect.....I've used it in spots like that...I even painted an engine block with it and it lasted for years (sold the car so no idea)....it can take the heat.
p.s....just be careful you don't paint it and allow it to lock up...the stuff is like cement.
De Oppresso Liber
Strength and Honor 5th Legion
Old 02-03-2016, 06:35 PM
KG Industries Guncoat
1977 911S silver/black
Old 02-07-2016, 02:29 PM
Mark Salvetti's Avatar
You should be able to slide off a clip and washer from the shaft of the flapper, and then pull out the shaft. This will let you paint the shaft, flapper, and body separately and avoid having anything lock up.
You can also buy hardware kits, including cable guide tubes and clamping screws. Pelican has them, so does Stoddard's.
Mark
1979 911SC Targa
Old 02-07-2016, 03:19 PM
I completely disassembled mine and painted everything with high-heat engine enamel. No issues.
Old 02-07-2016, 03:43 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Here you go... To get to the painting part. http://forums.pelicanparts.com/porsche-911-technical-forum/589980-cleaning-flapper-boxes.html
Who Will Live... Will See
Old 02-07-2016, 03:49 PM
RDM RDM is online now
Coram Deo
RDM's Avatar
I had mine blasted and powder coated. They are beautiful
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 02-13-2016, 08:11 AM
