New CHT installed. Orginal issue still remains. A bit smoother running, with improvement, but still not drivable. Next test is fuel delivery system, as suggested earlier.
Dave
Old 03-15-2016, 09:34 AM
Just may have found something. Idle position switch tests closed all the time. When I remove it from the harness, I have free revs and no further mis issue. Runs great but high idle. Could this be the root cause of my misfire? DME still thinks car is in idle mapping tables?
Dave
1984 Porsche 911 Carrera
2002 BMW R1150RT
2013 Audi A4
2020 Ford F150 4x4
Old 03-17-2016, 03:05 PM
scarceller's Avatar
If the idle switch is always closed you would not likely rev past the fuel decel cutoff set at 1200RPM. But a problematic intermittent idle switch would result in fuel cut at RPMs above 1200. I have seen bad idle switches, actually just saw one last week.
If you unplug the switch you will just remain in the Part Throttle maps and idle high, other than that no harm done.
If you want to see exactly how a shorted out (always closed) switch behaves, simply unplug it and jumper the 2 pins in the harness. Then try reving it past 1200RPMs, I bet lunch it dies and sputters right around the 1200RPM area.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 03-17-2016, 03:22 PM
Sal, I think you got it. I can rev past 1200 but only once or twice then breaks up. Must be hitting the limit. The switch tests continuity 100% of the time. Needs replacement. Seems PP can not get me one, do you know a source?
Dave
Old 03-17-2016, 03:29 PM
scarceller's Avatar
If PP does not have it, here you have a OEM factory part:
Throttle Body Switch Micro Switch 100 Genuine Porsche for A 911 Carrera 84 89 | eBay
This is the cost of this switch $200 crazy expensive for what it is. I've never seen anything but the factory part available. They run about $200 all the time.
While at it remove the WOT switch, most are easy to open up. Open it up and clean the contacts with 600 grit sand paper. If it's the newer sealed unit I suggest testing it as well to be sure it closes (reads 0 ohms) at about 80% throttle, once it closes it needs to stay closed all the way to 100% throttle.
Also be aware that the idle switch has a very specific procedure for how to adjust it. You DO NOT ever want the idle stop to become the switch! The idle stop must be the stop screw and the linkage must NEVER hammer on the switch. At idle stop you move the switch just enough so it activates (red button plunger) clicks on. You do not want excessive pressure against the switch as it will damage it, very likely what damaged that switch you have now. I usually remove the TB entirely from the car to properly set the stop screw and the switches, I also look very carefully at the throttle plate to be sure it's not hitting or rubbing inside the throttle body. Basically a good time to look over the entire throttle body.
Sal
1964 356SC (SOLD)
Old 03-17-2016, 04:45 PM
Thanks Sal.....I will do some additional searches as well tomorrow. How difficult is this to instal? Looks impossible!
Old 03-17-2016, 04:49 PM
scarceller's Avatar
Read my prior post, take the TB out of the car. Much easier to do this on the bench.
Sal
1964 356SC (SOLD)
Old 03-17-2016, 04:53 PM
steely's Avatar
Dave,
here is a pic of my intake removed, you can see 2 screws holding the switch plate (circled) at 9 o'clock. It might be easier to remove that plate and then replace the switch - not sure - it may be a 'blind' mate.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 03-17-2016, 04:57 PM
Sorry Sal, read your post on my cell phone only. Crap, never took the TB out. Steely...Thanks....this makes me think this a bit more of a job......
Dave
Old 03-17-2016, 05:03 PM
Got IT!!##
Thanks All for your guidance and support. I have a lot to learn....but,
My issue was a sticky idle microswitch. There was gunk holding the switch from opening upon throttling up. After 15 times of pushing on the switch with my finger, it loosened up.
Checks good and issue is resolved. Thanks again, you guys are great.
Dave
Old 03-18-2016, 10:25 AM
Running and happy...
Old 03-18-2016, 10:29 AM
Wow! A most impessive finale!!
How are Dan and Sal so smart???
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 03-18-2016, 10:30 AM
