915 transmission stuck in first gear
my 915 transmission in stuck in first gear. I can't go to neutral.
do you have any tips to unlock the transmission? I would appreciate your advices thank you |
Try rocking the car back and forth a bit while a helper moves the shifter. You'll need to investigate why it got stuck, though. I would start with the shifter bushings before digging into the internals.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Member 911 Anonymous
+1^^^
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Drain trans fluid and look for broken dog teeth in the fluid or on the drain plug. First gear dog teeth failure is not uncommon. Rob
915 trans stuck in first gear
I can mover the selector lever but the transmission is stuck still stuck in first gear.
As if something got disconnected inside the tranny |
Information Junky
I had a linkage pivot block come loose once, with similar result.
# 34 below. ![]() of course the problem could be anywhere along the linkage path. I would suggest checking the coupler (under the tunnel cover, behind/between seats.) Keeping in mind that 1st pushes that rod, and second pulls (read: can pull out, leaving it stuck in 1st)
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Shift rod coupler came off the splined shaft or shift rod bushings are bad.
Yeah, never had one firmly stuck in 1st. If you had mentioned that the shifter moves in the original post, we could have arrived at the bushing diagnosis earlier.
+++ gomezoneill
Mine stuck in reverse. The car would move backwards but when I selected a forward gear I could stall the engine. The transmission was locked. I pulled the inspection plate at the tunnel and could see the shift rod had about 3/8" of exposed clean metal on the spline shaft indicating the shift coupler had lost its grip on the rod. After adjusting the tunnel shift rod and tightened the coupler again. Problem solved Hopefully yours is as simple as mine was. |
greyes; are your back-up/reverse lights on (with ignition on, of course)?
Keep the Shiny Side UP! Pete Z. |
My friend got his VW stuck in second gear and was able to go in through the hole where you add oil with a long screw driver and get it unstuck.
