Fuel Delivery Issue - 3.2L Carrera
I was out on a run this weekend and after a brief stop I went to start the car. Starter motor going, engine not starting. After a couple more attempts I figured I wasn't getting any fuel. On a fourth attempt I had my son engage the throttle from the engine bay as I turned the engine over and voila! ---- the car starts.
After a brief drive I noted an an upshift into second that I lost power for a half second or so and continued on. I noted this one more time just a short while after. On a related note, in the past few weeks I have noticed that while at a constant speed on the highway the car would lurch for a millisecond or two --- kind of like the clutch was slipping. I am thinking that this is related. I was able to drive home without any issues and had two more stops without any issues starting. Any ideas on what this could be? Most likely culprits? Cheers and thanks, Kato |
do you have a spare DME relay? It activates the fuel pump, etc. and can develop bad soldier joints that cause intermittent failures. Easy to rule it out by replacing with a spare
^ do some searching on DME relay. Sounds likely and similar to issues I had. You can jumper the pins to eliminate it but that wont help if its intermittant.
Love your Avatar! they just dont make movies like that any more.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Member 911 Anonymous
+2, swap relay and keep us updated :-)
You should have a spare non-Uro one.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thanks much. |
Thanks .... yes .... classic. Aliens is my favourite Sci-Fi film. Early James Cameron work. When my kids and I watched Avatar they said, "hey. didn't they have those in Aliens" Referring to the machinery, of course.
I'm dealing with this in my 88 right now. I had the same lurches as you, then the car died. I got it to run briefly several times but not long enough to drive it. Eventually it wouldn't start at all. In my case it wasn't the relay. I've confirmed I have spark (after something of a wild goose chase) and now I'm preparing to test the fuel pump. Follow along at http://forums.pelicanparts.com/porsche-911-technical-forum/916075-broken-down-near-pt-reyes-ca.html
1988 911 coupe 1976 Vespa Rally 2015 Honda HR-V |
Just to update ... yes ... it was the DME relay. Changed it over and no problems at all. Cheers, Kato |
