Originally Posted by Shaun @ Tru6 View Post
Thanks, I do fan restorations as well and use Cerakote.
I'm picking up a 2.7 RS longblock this weekend and will need Webers or an EFI/ITB system for it.
Very cool! I'll reach out to you next time we're doing one.
Old 08-23-2016, 02:43 PM
clutch-monkey's Avatar
Originally Posted by darud35 View Post
It's a ceramic coating. I can't recall what color, it looks like a protective coating with the natural finish. There's a guy here in So Cal that does it.
i swear i've seen it applied to rifles haha
Old 08-23-2016, 04:56 PM
Love mine so sharing as well.
Old 08-23-2016, 06:33 PM
I just acquired a 1997 engine in an 88 Carrera Coupe -3.6 ,with
KMS engine management and itb's-System is a KMS25
sport cams ,Rarly headers
2/2 rsr muffler w jethot coated headers and muff.
MP25 management ECU Specs are listed below-(they are big with the BMW guys)
System has been used in a exclusive use track car for the last 5-6 years with 100 % reliability.
<http://kms.vankronenburg.nl/wp-content/uploads/2012/03/01-01-01-0001prof.j
pg>
The KMS MP25 ECU is an affordable and efficient engine management system.
By using the minimum of sensors, three auxiliary outputs, one auxiliary
input and a wide range of functions, the KMS MP25 ECU can cope with 90% of
all types of Otto engines.
These basic functions make the MP25 a simple, reliable and effective
engine management system at a very competitive price.
‘This is a engine management system designed by engine people to be used
by engine people. Anyone who understands the mechanics of the Otto cycle,
should be able to set up and use this system with little difficulty.’
Features:
* Complete engine management system up to 10 cylinders
* Self-learning lambda control in combination with KMS UEGO controllers
* Engine diagnostics
* Short cut protected outputs
* Serial RS232 communication
* External dashboard (KMS CAN display in combination with interface)
* 2 engine load sensors
* Analogue input (2nd lambda, gearbox position, G-force sensor, EGT, etc.)
* 3 auxiliary outputs (Shiftlight, water-injection, cooling fan, etc.)
* Pit lane limiter (variable)
* RPM limiter
* A.L.S. (variable)
* Powershift (separate delay and cut-off time for each gear)
* Boost control
* Launch control (variable)
* Idle control
1979 SC
1986 Carrera 3.6 L+
Old 08-23-2016, 07:53 PM
Chain fence eating turbo
^^^^^ Not a good sign their webpage is not active!!!
Old 08-24-2016, 04:49 AM
Wer bremst verliert
JohnJL's Avatar
It looks like the poster's error: he copied the url for a picture of their ecu but when the forum renders the page it de-linked "pg" from the end of the address which SHOULD be ".jpg." Add back the "pg" at the end and the pic of the ecu comes up properly.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 08-24-2016, 05:12 AM
gt3racerich's Avatar
I have been thinking of going with ITB's after speaking with Al about a rebuild.
At this point I have a pretty good running 3.2 (other than oil leaks) with Motronic DME.
What should I expect changing to ITB's and how would they compare to the Motronic FI currently on the car.
Thanks, Rich
Looking for a 1970-1973 911 coupe, no sunroof. Matching numbers and originality are unimportant.
Old 08-24-2016, 07:56 AM
Mick_D's Avatar
Hey Al, do those S3 ITB's come polished? Is there a reason they aren't lined up and perpendicular?
I'm shopping around for a running 3.2. In the future, ITB/EFI/EMS is a definite thing.
Originally Posted by al lkosmal View Post
Here's a 3.0 I built a few months back.
JE 9.5:1
E-ish cams
x-faktory S3-EFI/ITBs
Rasant engine management
COPs
headers
sport muffler
Old 08-24-2016, 10:13 AM
Ken911's Avatar
Still not done Making the plenums and intercooler. But here is the link to mine, it's a turbo so a little different . I made my own manifolds got the ITB's from Jenevy and also the linkage.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/763281-well-i-its-finally-time-pull-out-efi-swap-will-long-one.html
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 08-24-2016, 10:29 AM
al lkosmal's Avatar
ITBs
The velocity stacks do come polished or powder-coated. The ITBs are lined up, but are slanted inwards, by design, at approx 10 degrees from vertical.
RGruppe #669
http://www.x-faktory.com/
Old 08-24-2016, 11:14 AM
Cars Ruined My Life
impactbumper's Avatar
pretty active to me LOOK HERE
they seem to be not so much into social media. Velocity stacks for the M cars are delicious.
Old 08-24-2016, 05:01 PM
Cars Ruined My Life
Al that engine looks delicious. Got your email btw, going to respond shortly.
Old 08-24-2016, 05:03 PM
al lkosmal's Avatar
thanks....give me a shout and we can discuss.
regards,
al
RGruppe #669
Old 08-24-2016, 05:59 PM
The KMS stuff seems way legit. I had them quote me the setup, before I decided to stick with carbs and a 12 plug.
https://www.youtube.com/watch?v=Fqkzn5IMOFI
Old 08-24-2016, 06:05 PM
al lkosmal's Avatar
Dzug Dyno
Here's a dyno run of the Dzug 3.2SS...the dyno sheet is a composite that shows the before and after. Before is Bosch CIS, after is my x-faktory EFI/ITB system...no other changes were made. (dotted lines are before, solid lines after)
a couple vids..one of pre-dyno road test and one of dyno run
https://www.youtube.com/watch?v=pxXwaL_TdmY
https://youtu.be/xaj0FyEmc68
I wish those guys were still around...they had mad skillz....
regards,
al
Al Kosmal
the x-faktory
koz@x-faktory.com
RGruppe #669
X-Faktory - Home
RGruppe #669
Old 08-24-2016, 07:04 PM
Old 08-25-2016, 06:59 AM
IXjamesXI's Avatar
Originally Posted by metalracer View Post
Holy smokes!! Beauty all around.. That plenum! Totally custom fabbed I assume? And that air filter.. is that something off the shelf? Very cool.
'82 SC Coupe / Pacific Blue
Old 08-25-2016, 09:19 AM
Ferrino's Avatar
Thanks, Rich
Although I am nowhere near getting my ITBs running (42mm bike throttles, Microsquirt ECU), my goals in converting from the Motronic ECU/intake on the 3.2 are: much improved throttle response, modern & mappable ECU for tuning, visual and acoustic delight, losing the archaic AFM "barn-door". The big two for me are throttle response and induction sound. My previous project was a motorcycle-engined car and although I will never get the instant throttle response of a 998cc bike motor, I am expecting to recover the ITB orchestra that is so locking with the Motronic plenum.
Ferrino, thanks for the reply.
That sounds good, I would be looking for the same characteristics.
Rich
Old 08-30-2016, 06:36 AM
I would rather be driving
jpnovak's Avatar
I have been installing EFI using MFI stacks. This retains all of the factory induction for early cars. Includes flex line fuel feed like the RSR-MFI systems.
Currently building 2X 3.0s and a 2.8 with the same system. This does require MFI ports installed into the head.
Available from our host.
Old 08-30-2016, 07:17 AM
