rudycraigs's Avatar
Replacing old style transmission mount?
How to replace 901 transmission mounts?
Hi I have a 1969 912 with a 1970 911/01 transmission. My trans is being rebuilt and I would like to replace the transmission mounts with new. According to the pelican article:
Porsche 911 Motor and Transmission Mount Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
“The transmission mounts are very similar to the motor mounts, except for the early cars. Unfortunately, the early cars have a once piece mount and support bar design that is no longer available. “ “The later style 911s (1972-on) were equipped with a transmission mount bar that incorporated replaceable mounts."
Whats the fix? How can I get new mounts in a 69 with the one piece bracket? Can I press new rubber mounts in the old bar? A >=1972 mounting bracket with removable mounts was for a 915 trans right? Can that work or will it need special shimming?
I know this must have a simple answer? Thanks ahead of time.
Old 08-23-2016, 06:36 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/744845-pendulum-outlaw-build-adventures-misadventures-6.html
Scroll down, a bit of work but this is how I put new bushing in
Outlaw .... by definition ..... does not follow rules well
www.FloydDesign.ca
https://www.youtube.com/watch?v=sV5aIALWlG8
Old 09-05-2016, 06:38 AM
Ubi bene ibi patria
Hawkeye's-911T's Avatar
Another possible alternative (?)
HOW TO: Replace 911-style transmission mounts
Cheers
JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
"As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras
Old 09-05-2016, 09:58 AM
Ubi bene ibi patria
Bituva thread bump. Any of you folks care to comment on the efficacy of the above alternative solution to the OP's question. I am facing a similar situation.
Cheers
JB
Old 09-12-2016, 01:25 PM
Bumping an old thread.
The mounts referred to in the "how to" are no longer available from Pelican. Does anyone know another version or option for these mounts?
https://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=PEL-RSRMTM&catalog_description=Poly-Graphite%20Engine/Transmission%20Mount%20Insert%20Kit,%20911%20(1965-89),%20911%20Turbo%20(1976-89),%20or%20Transmission%20Mount%20for%20911%20(19 72-89)%20915%20or%20G50
Old 02-07-2022, 05:17 PM
boxer246's Avatar
Re-bumping old thread since im not seeing much solution here. Are the Rennline mounts the only replacement mounts available for the old style mount? My transmission shift rod is not centered in the hole through the tunnel leading me to believe my mounts are sagging?
Old 08-23-2022, 08:07 AM
I would rather be driving
jpnovak's Avatar
Best solution is to send the mount to WEVO and have it modified for the later mounts. Or you can do this yourself if you are competent with a welder and have a 915 mount.
Another option is to use a 915 mount and relocate bolt holes and reinforce.
There are some polyurethane mounts that can be installed. I have never tried these before.
Old 08-23-2022, 08:17 AM
jpnovak's Avatar
I just looked. Rebel Racing has these mount inserts. They are pressed in.
Old 08-23-2022, 08:19 AM
boxer246's Avatar
Thanks Jamie yes I just saw the Rebel ones right after I posted that. Contacted them they said they are a two piece mount that goes in easily after drilling/cutting out the old rubber one. Seems like the best option.
Old 08-23-2022, 12:54 PM
Tags
tranny , transmission mounts , transmission support bar
