915 split
For some reason I can't split my center case from rear ? All gears are off where nose peice is? Only moves about 3/4 inch? What am I missing
Old 08-30-2016, 09:43 AM
Something similar happened when the roller bearing failed in my 915. The case halves would only separate enough for the mechanic to get a wrench in and undo the bearing retainer nuts. That allowed the case to separate, and all the rollers fell out onto the floor.
1986 3.2 to 3.4 conversion
Old 08-30-2016, 09:58 AM
Tranny should be in great shape interally. It's fresh rebuild. Taking apart to powder coat caes
Old 08-30-2016, 10:22 AM
gearhead
Did you remove the detents?
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 08-30-2016, 11:22 AM
Detent?
Old 08-30-2016, 11:43 AM
gearhead
Detents are little balls that get loaded into cut outs in the rods to hold it in gear.
Here's page 2 of Pete Z's. Wiki
How-To: Porsche 915 Transmission Repair Tutorial Part 2 - Porsche Wiki
First would be have you removed the cover plate? Also be sure you are in neutral.
1974 914 Bumble Bee
2009 Outback XT
Old 08-30-2016, 11:53 AM
Ok. Cool
That's what I'm following. I didn't see anything about detent until the case is off. I'm pretty sure it in neutral?
Old 08-30-2016, 12:32 PM
