The 9 Store
I picked up mine from eBay.
All used parts sold as is.
Old 02-15-2018, 09:35 AM
A pelican named Ftech9 is the man who developed these solid state
DME relays. Perhaps send him a PM asking about future availability.
By the way, he hasn't posted since March of 2016.
Here's his original post from when he was developing them. Just did a search on Ebay and found none.
http://forums.pelicanparts.com/porsche-964-993-technical-forum/873271-solid-state-dme-relay-beta-testers-wanted.html
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 02-15-2018, 10:07 AM
very interested in solid state, and reading through all of this debate to pump-prime or not.
do we know how it works, or doesn't work, with an SW chip installed?
my assumption is the SW chip was designed with a stock non-pump-primed system in mind and to introduce more info to the system could be confusing but i really don't have any real knowledge on this. any experience is appreciated, thanks.
'85 911 Coupe, '02 P38, '89 E30 Touring, '89 GB500, '96 XR400
Old 06-10-2019, 09:24 AM
I have had the solid state relay with pump-prime for several years (including when I had a Steve Wong chip), and it works flawlessly. I love this relay.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 06-10-2019, 10:18 AM
Burnin' Rubber
Koizumi's Avatar
Solid state DME Relay conversion ?
I went for the fuel-priming version as well. I also have a Steve Wong chip.
I do keep a working spare DME relay and 2 red relays in my glovebox.
Works wonderfully. I highly recommend the fuel priming version. As previously stated, hearing the pump whirrr before ignition is a crucial troubleshooting issue that can easily be checked off of a no-start diagnosis.
Old 06-10-2019, 10:30 AM
I also have had the SS pump prime relay installed for several years with an after market chip and it works flawlessly. I assume the 3 second prime function is built into the DME relay using a time delay circuit and has nothing at all to do with the ECU or chip.
Get one they are great, and you can forget any DME relay worries!
Old 06-10-2019, 10:35 AM
wrxnofx's Avatar
I got the pump priming version of this relay about 2 months ago. It seemed like initially the crank time on my '87 was WAY shorter. Now, not the case anymore.
I have also had 3 separate occurrences where the engine dieseled after shutting off the car. Maybe 1 or 2 seconds each time. I never had this problem before installing this relay. Anyone else?
I reached out to the guy but got crickets, so I thought I'd ask here if anyone else has had this problem.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 08-09-2019, 10:05 AM
That's fond- just deglaze
Hi @wrxnofx- I think we both installed ours at the same time- no issues yet. That dieseling is quite odd. I do have a spare DME (OEM) if you want to swap it and check!
Missed Approach
Petra- 1986 Coupe
Old 08-09-2019, 05:27 PM
I have the non priming version on mine and have been happy with it. Installed mid 2017, no issues.
Ralph W
Instagram @ ralphwlll
1990 C2 Cab
2006 Nissan Frontier
1986 F250
Old 08-09-2019, 07:00 PM
Sorry I have a 964
Ralph W
1990 C2 Cab
1986 F250
Old 08-09-2019, 07:04 PM
Ctopher's Avatar
I’ve had the priming version on my car for about a year this August. I have not had any issues with the car but the dieseling is something I’ve noticed from time to time both before and after the solid state DME. In all cases that I remember I slowly turned the key to turn off the car, almost as if power was pulled and added back. Since I realized that I’ve done a quick turn off of the car and have not had another occurrence. Not sure if others have noticed that turning the key slowly causes this.
CTopher
Old 08-09-2019, 07:08 PM
The web site for his solid state DME is Focus 9 Technology, LLC
I bought the 2 second prime version, and have had it for two years and over 11,000 miles with flawless operation.
Old 08-10-2019, 09:57 AM
I have used the prime version of the Solid State DME relay for three plus years on my 964 transplant motor with not a single problem. Still keep a spare original DME relay in the glovebox just because. The SS DME has been one of the best buys ever for my 911.
Old 08-10-2019, 10:08 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Anecdotal, fuel pressure is fuel pressure, the fuel injected into the engine is through the injectors. The fuel pump is either on or off.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 08-10-2019, 05:49 PM
Non-prime on a 993 here. Two years, no issues, stock one is still in the car as a spare.
Old 08-10-2019, 09:57 PM
Vulnerari Praesidio
Is there a current preferred source for a SS DME?
"Wisdom is knowing what to do next; virtue is doing it."
- David Starr Jordan
Old 08-11-2019, 08:06 AM
Formerly known as Syzygy
Canada Kev's Avatar
He has them in stock currently.
Kevin
Old 08-11-2019, 10:14 AM
wrxnofx's Avatar
And yet my engine's behavior has returned to normal having swapped back in the original relay.
Old 09-03-2019, 06:27 AM
The fuel injectors are either on or off. The relay only controls the electricity powering the pump. Your after running is coming from some where else.
Old 09-05-2019, 05:21 PM
nothing to see here
Can anyone explain why the prime and non-prime versions of the relays appear to have different pin orientations with respect to the mounting tab? I have emailed Joe but had a confusing reply.
This photo is from their website.
Old 03-02-2020, 07:12 AM
