-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   2 911 G50 Builds at the Same Time (http://forums.pelicanparts.com/showthread.php?t=931336)
rolfjahn 07-07-2020 03:52 PM
Installed Leather Engine Pad and noticed Wevo Cradle Mounts
http://forums.pelicanparts.com/uploa...1594165462.JPG
Both builds live in the garage most of the time...
I of course jumped down the rabbit hole because I've been locked up at home.
There must have been moisture because the was light surface corrosion everywhere.
rolfjahn 07-07-2020 03:56 PM
Some Disassembly Required
http://forums.pelicanparts.com/uploa...1594166015.JPG
Removed everything and glass bead blasted and cleared to eliminate the humidity / moisture related corrosion.
rolfjahn 07-07-2020 04:11 PM
Eastwood Matte Clear is good to 300 Degrees
I've always had good results with Eastwood clear.
It's very durable and easy to clean.
http://forums.pelicanparts.com/uploa...1594166282.JPG
The Eastwood metallic metal look paint takes around 4 days cure to a hard finish
The Eastwood clear is dry to the touch in about 15 minutes with 80+ degree
high humidity Florida weather.
Played around with the faux anodizing paint-it will be hidden under the induction system.
Not a real fan but I'll eventually get better at it. (Still keeping it out of sight)
Time to call TRUE6 to get it done professionally.
rolfjahn 01-01-2021 05:26 PM
Singer Style Mirrors-Be Jealous - Except for the price...
http://forums.pelicanparts.com/uploa...1609554283.JPG
rolfjahn 01-01-2021 05:35 PM
I have a leather problem now
http://forums.pelicanparts.com/uploa...1609554596.JPG
Dumb Dumb is guarding my induction system
I got my injectors back!
rolfjahn 01-01-2021 05:53 PM
And the documentation and cost plot gets thicker
http://forums.pelicanparts.com/uploa...1609555817.JPG
mikedsilva 01-01-2021 07:09 PM
wow
rolfjahn 05-19-2021 02:03 PM
Hi Everyone,
Been stuck at home working and of course losing my mind doing Zoom meetings all day...
Overly expensive wheel studs and spacers-but they look really really good
http://forums.pelicanparts.com/uploa...1621460360.JPG
In Pursuit of that perfect ride height, 1 degree stance and perfect un-obtainable wheel spacing
Got a 100 mph Covid toy that can end my life anytime I try to start it
Its got a fuel pump in the tank and an injector you have to energize
3 programmable modes of insanity and 68hp on a 250lb frame
Suspension has a steering stabilizer with springs instead of air
Garage got a new floor-the biggest mess known to man comes from cement dust
Embracing my leather problem-lots more pictures to come
rolfjahn 06-19-2021 12:18 PM
Working on the Guards Red wide body
http://forums.pelicanparts.com/uploa...1624132682.JPG
Never enough nuts, bolts, glues, tools and stuff in cans...
Cleaning / Refinishing all parts for the induction system
Brought the Spinney-Beck leather weave to All in Leather in Miami
Original fitting without a fiberglass mold this time in the Granite Green
http://forums.pelicanparts.com/uploa...1624132682.jpg
Requested the French seams with red stitching
I make cardboard templates for the diamond stitch panels for the engine
Parcel tray had to be redone because my Guard Cat used it as a scratch post...
Rear side panels with weave and smooth Nappa black leather
rolfjahn 06-19-2021 12:25 PM
Glass bead blasted the engine tins and prepped and painted with John Deere black lacquer and Eastwood clear
http://forums.pelicanparts.com/uploa...1624134011.JPG
Should have just dropped the motor...
OMG a BMW part! - Look at the right A pillar-stitch line is wonky!
daepp 07-27-2021 12:52 PM
Please do tell???
http://forums.pelicanparts.com/uploa...1627419138.jpg
(ps Great build too lol)
rolfjahn 08-13-2021 07:22 PM
Thanks, Clocks are from different people from ESTY...you need to check often. They make a great mechanical noise with 5 of them running.
rolfjahn 05-19-2023 06:40 PM
Pictures are finally loading.
Been working on the two Pcars again and definitely got sidetracked with having 2 Formawerx keys made for the cars. Ordered 2 150 amp alternators and Classic Retrofit electric AC.
http://forums.pelicanparts.com/uploa...1684549803.JPG
rolfjahn 05-20-2023 08:23 AM
Checked all wiring and found that only the factory sheathing was getting old, the quality of factory Porsche wire and the insulation is amazing.
Disassembled the injector wiring harness and created new sheathing with high quality
glue lined shrink tube from Wirefy.
Then got obsessed and went for all the wiring harnesses.
http://forums.pelicanparts.com/uploa...1684598494.JPG
Kitchen is the perfect place to do wiring I'm told...
Injector wiring, keep track of left and right banks
Custon switch panel in aluminum with relays
http://forums.pelicanparts.com/uploa...1684598494.jpg
Red Head wired back up after 2+ years, fired back up on the first try.
rolfjahn 05-20-2023 08:37 AM
Got Side Tracked
Formawerx keys for the RedHead and Granite Green
http://forums.pelicanparts.com/uploa...1684600084.jpg
Very Cool Keypiece capsule
RedHead engraved key
Very custom dash-oil pressure is blood pressure
The documentation keeps on growing
Granite Green (GG's) Formawerx key
rolfjahn 05-23-2025 10:09 AM
Back in the Saddle-Will be posting build pictures in a couple of weeks-lots of wiring and some leather
