wow
As noted above, when i first set these up I was going to use cable linkage. The way the linkage hooks up to the ITB's is on the fuel rail side. This would have allowed the bellcrank in the middle of the engine, with the cables running under the ITB's to hook up to the ITB linkage. It could have worked the other way around, but it would have been tight. This configuration gave me a little more room with the cables to sweep around. Also for my fuel setup I was mimicking the fuel setup from a 3.2 with the fuel rails on the outside. |
Wiring has continued
All new connectors and terminals were used for every plug. Insulators on the coil pack wires http://i35.photobucket.com/albums/d1...ps0ukghwyt.jpg Wires stripped http://i35.photobucket.com/albums/d1...ps9cz8swws.jpg Terminals crimped http://i35.photobucket.com/albums/d1...pskdcfco1y.jpg Braided wire wrap on http://i35.photobucket.com/albums/d1...ps1ydg73pw.jpg Plug on, heat shrink shrunk http://i35.photobucket.com/albums/d1...psjjrodgd0.jpg And repeat http://i35.photobucket.com/albums/d1...pso94xaprn.jpg |
Beautiful wiring job! When I redo mine, I'm going to crimp rather solder, so 0 splices.
Clay,
Where did you get the rod for the bell crank on the manifold? Also, what bushing did you use on the passenger side to mount the armature linkage? -Steve |
Hello Clay,
Is there any chance I could buy a pair of your intake manifolds? |
Very nice work. Tempted to follow in your footsteps, which means I have the same question as DeRRis.
Mesmerizing.
I'd also like to know what I can do to acquire a set of your manifolds Clay.
Dennis - I appreciate the plug, but let's try to keep this thread about the build!
While the wiring was moving, I also worked on the fuel. The car was setup previously with Weber's and had a low pressure fuel pump installed. http://i35.photobucket.com/albums/d1...psusysmd2j.jpg I used an AEM unit to replace it. http://i35.photobucket.com/albums/d1...psyqrujxeu.jpg http://i35.photobucket.com/albums/d1...psumvyryei.jpg http://i35.photobucket.com/albums/d1...psujzbaucy.jpg http://i35.photobucket.com/albums/d1...psvrer4wbz.jpg |
So more wiring. I missed this pre-install pic of the main harness
http://i35.photobucket.com/albums/d1...psisfxer0p.jpg Laying out the wire runs to all of the sensors http://i35.photobucket.com/albums/d1...psnui34kof.jpg And installed a -6AN fuel line between the two rails https://c3.staticflickr.com/6/5550/3...55457ce8_c.jpg https://c6.staticflickr.com/6/5769/3...e28dbf07_c.jpg Vacuum lines from each TB to a vacuum manifold https://c2.staticflickr.com/6/5459/3...2f4ec28c_c.jpg |
The injectors are 30lb units supplied by Rasant Products
https://c7.staticflickr.com/6/5775/3...2e15fc5c_c.jpg https://c8.staticflickr.com/6/5643/3...1fba3cb2_c.jpg The coil packs are Audi 2.0T units, these are a little long but do the job for now. There is a short variant that i'll be switching to shortly. https://c7.staticflickr.com/6/5549/3...3a661104_c.jpg For oil pressure, I used a universal 0-100psi 0-5v sensor with an adapter at the high pressure port location https://c3.staticflickr.com/6/5772/3...dcbdb4cf_c.jpg This is the fitting - M10x1.0 M10 1.0 1/8 NPT Oil Fitting Pressure Tee T Adapter http://i.ebayimg.com/images/i/161914...0/s-l140/p.jpg For oil temp, I used an AEM 1/8 NPT temp sender with a Auto Meter 2267 Oil/Temperature Metric Adapter in the cam cover https://c7.staticflickr.com/6/5819/3...7ab06ddc_c.jpg For IAT, I used an AEM 1/8 NPT unit that I drilled and tapped into one of the ITBs https://c6.staticflickr.com/6/5524/3...cca28f1e_c.jpg As noted previously, I used an universal vacuum manifold to collect all the vacuum lines off the ITBs. This serves the GM 1 bar map sensor and vacuum reference for the fuel pressure regulator https://c7.staticflickr.com/6/5468/3...236266b7_c.jpg https://c3.staticflickr.com/6/5761/3...3a8afb65_c.jpg I also added a spring to the bellcrank linkage to help the throttle return https://c8.staticflickr.com/6/5697/3...d02c99fa_c.jpg |
Wonderful stuff - I especially like your photography. Regarding the Audi COPs - I picked up a used one just to see how it would sit against the holes in the valve covers and mine was just loose in there - really didn't like that. I guess you could put some sort of spacer ring in there. Do the shorter ones actually rest against the covers?
Beautiful install!! I'm in your town as we speak.
That's pretty sweet, CLay. One day I'll want to do something very similar. Those Triumph ITBS look great!
Kudos, nice adventurism, creativity, documentation and bravery. Keep it coming.
What crimper are you using? Are they double-crimp?
| All times are GMT -8. The time now is 04:43 PM. |
