G50911's Avatar
LWB wiring harness install
hey folks. i'm just about to start installing my wiring harness on my 71 LWB project but unfortunately, i didn't have the luxury to take pics before it was removed. does anyone have any detailed pics of the wiring they can share? looking for pics of the tunnel routing, front trunk and rear engine compartment. links to other pages or videos welcome too!
1967 911 (Azzuro Thetys) - #308439
1971 911 (PTS Black) - Built 3.6 Sleeper
1989 911 (Grand Prix White) - Cabriolet Bone Stock
Old 06-15-2017, 01:22 PM
Banned
Subscribed
Old 06-15-2017, 01:57 PM
Also subscribed, I've been looking for the same. I have a collection of pics from different cars, but nothing complete yet.
___oOo___
1972 S 911 Targa kit
http://forums.pelicanparts.com/porsche-911-technical-forum/863768-thats-my-first-911-restoration-thread-72-911-s-back-grave-maybe.html
Old 06-16-2017, 03:36 AM
G50911's Avatar
friday bumpage...
oh and florio, can you post some of your pics? i found this video on you tube that is helpfull but am really looking for details like where to start. feed from the front trunk and run all the way back? start from the back and feed everything forward? etc.
https://m.youtube.com/watch?v=cs6Cy56axnI
Old 06-16-2017, 12:13 PM
Ubi bene ibi patria
Hawkeye's-911T's Avatar
Sub'd as well. I am presently phiddle-phartin about with a 'customized' to wit: seriously buggered-up wiring system in the trunk. The relationship between what I have (1970) & the schematic (SL35) is coincidental at best.
Cheers
JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
"As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras
Old 06-16-2017, 12:19 PM
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Dennis?
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 06-16-2017, 01:44 PM
ROW '78 911 Targa
timmy2's Avatar
Originally Posted by emptyo View Post
Dennis?
Lol Mike,
Here is a thread from a week or so ago. (Even less) Advanced search is your friend..
http://forums.pelicanparts.com/porsche-911-technical-forum/957801-pulling-wiring-harness.html
Install is the reverse of removal.
Maybe the OP should connect with the guy that is just removing his harness and get him to take photos and make notes...
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-16-2017, 02:21 PM
G50911's Avatar
unfortuantely the guy pulled the wiring over 2 years ago and is now in jail [facepalm]. i saw that post but it still didn't show where the wiring goes once it's out of the tunnel and how it snakes thru the driver footwell up and behind the dash.
also, looking at my harness theres A TON of wiring bundled up front and less out back. that's why i'm assuming there's a trick to getting it thru the tunnel and slid up in that passenger side channel. seems counter intuative right now and need some help.
Old 06-16-2017, 02:36 PM
It goes in through the back
But, you have to undo everything up front that the back harness hooks up to.
I just pulled mine, had to undo the back stuff at the fuses. Then one line hooks to a gauge. It was a PITA.
I would imagine it's going to be very difficult with the floor in. I'm going to run a pull wire. It also slides in its own wiring tunnel within the tunnel. I'll have a picture of this soon, I'm pulling my floor now
Old 06-16-2017, 02:54 PM
cnielsen's Avatar
A new harness is much easier to pull through since the wires aren't all kinked. I have installed a couple of Dennis' harnesses and pulling them through the tunnel is pretty easy. use a chase wire or fish tape and use that pull everything else through.
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 06-16-2017, 03:04 PM
The tunnel pictures are good, but were already posted in several threads. What would be better would be to see where the harness runs out of the tunnel to the fusebox. There were some good pics in the blog by Mike Caterino, but unfortunately it's no longer up. I also had a good picture of the engine compartment without the engine, but it went into hiding.
fusebox pictures here:
http://forums.pelicanparts.com/porsche-911-technical-forum/882337-1972-fusebox.html#post8786823
Remake your wire harness:
http://forums.pelicanparts.com/porsche-911-technical-forum/522541-911-electrical-complete-re-wire-wiring-harness-info-advice.html
http://forums.pelicanparts.com/porsche-911-technical-forum/819973-difference-between-wiring-harnesses-69-71-a.html
These pictures are reproduced mostly from auctions and without really asking, so if you're the owner and unhappy, then pm me and I'll take them off
___oOo___
Old 06-16-2017, 03:08 PM
G50911's Avatar
florio, this is super helpful. and thanks for the reply worky ���� i'm gonna try and get the wiring harness in and then figure out the routing as i go. i'll snap pics too so hopefully someone can use it later.
Old 06-16-2017, 03:33 PM
ROW '78 911 Targa
timmy2's Avatar
Tape everything up like a long snake tight in a line. Pull it in from the back with a rope you route through the tunnel. The through body harness splits up behind the dash into 3 main sections. One to the dash gauges, one to the rear defogger, fog lamp switch, lighter area, one to the fuses.
Don't forget the wires to the brake pedal switch if you have one.
No idea what stage your car is in, so it is hard to offer suggestions...
Maybe post some photos of what you are working with.
Dennis
Old 06-16-2017, 05:11 PM
do these help?
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 06-16-2017, 05:24 PM
G50911's Avatar
Originally Posted by RSTarga View Post
do these help?
oh hell yes! any chance you can show me what it looks like down behind the pedal cluster?
Old 06-16-2017, 06:35 PM
That is simply excellent! +1 on the pedal area. Any chance of also seing the passenger side of the frunk?
Thanks!
___oOo___
Old 06-17-2017, 10:01 AM
