French Import
Clearance for engine drop
Has anyone measured the clearance required to drop the engine (my car is an 86 cab)?
Assume the airbox and heater fan assembly removed and rear bumper still on(but removed if needed). Of course the type hydraulic jack or table will make a difference too. Just wondering ballpark out of curiosity. I have read many thread on engine drops but do not recall seeing a measurement. TIA
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Administrator
Have you taken a look at our engine removal DIY? There aren't measurements, but it might be useful and shows you images of the process. You can also post a comment at the bottom of it and our tech might have some input for you. Hopefully some other Pelicans chime in with some advice as well. Good luck!
Porsche 911 Engine Removal | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article |
if it helps I use the 6 ton jacks from harbor freight. I think I set them as hi as they will go or close to it and put them under the rear torsion bar ends.
I use a pretty tall tranny jack and may have left the IC on my 930 engine last time and still had to drop the front of the car down (with no wheels) and I had the bumper off. BUT, again, I have very tall tranny jack I use. I have never been able to get a tranny out from under a car with one on the jack except for my daughters F250.
For the most accuracy for your situation, you should just get a level/straight edge combo, set it up at the top of the engine compartment opening, and measure from that point to the bottom of the bumper. Add the height of whatever apparatus you are using to lower the engine and you have your requirement. Originally I had used a harbor freight hydraulic table and it added to much height that by the time I lifted my car as high as my jack could, I still had to remove my rear bumper. When I pulled it last year, I used one of the jacks and replicas of the factory drivetrain carriers you can buy from our host and I didn't need to pull the bumper. |
French Import
Also this is not my first drop. I just wanted to document and maybe do a write-up at the end.
French Import
I understand your challenge with the IC still in place.
French Import
The ATV lift I am using is from HF and is approximately 5 1/4 inches tall. I haven't figured out what amount of lumber I need to add, if any. Your figure of about 30 inches seems reasonable. Thank you!
Administrator
Enthusiast Tech Article Submissions - Pelican Parts |
disband
about this high
actually I use the taller of my two sets of jack stands on cinder blocks. also, as you can see it's best to have a jack on either side and go up & down just a jack stand click at a time.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
French Import
Would you happen to have a photo of the front end? I am curious about how the front wheels are chocked and if the front valence hits the ground. Thanks!
Administrator
I just removed my engine and the bottom of the torsion bar is 26" from floor level. I used an ATV jack to slide the engine out.
Walt 82SC 3.0 81SC 3.6 |
French Import
Thanks Walt!
French Import
disband
no pic of the front. simply chocked with wood blocks. the valence was likely making contact with the ground but since it's a middie no fog lights to be concerned with. picking the front end up is counter productive to getting the rear high enough if you had not already figured that out. if the valence is a concern id consider a couple of 2x6's under the front wheels to pick it up some would prolly keep from grounding it.
French Import
Funny how much low-tech lumber we use with our classic cars!
