Occasional User
That engine is an amazing piece of mechanical art and design. Does anyone else besides me have a bit of a problem with the bolt on / bonded RWB look of the rear fenders shown in all the pics? The rear fenders on current Singers are works of art. Do pics indicate wider tires/wheelbase are needed to handle the power increase?
Vince 2015 Boxster S, Black & Black 1989 Carrera Silver Coupe, Silk Grey - sold 2009 Cayman S White, Full Cocoa - sold 1972 911E Silver Coupe, Pepita & Black - sold |
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C Last edited by JacobS911; 08-09-2017 at 05:46 PM.. |
Occasional User
I agree the 934 is cool, but for me the Singer style is way more.
It won't have a carbon chassis. Perhaps some suspension components, but a carbon chassis would require them to become an actual vehicle manufacturer (kit car even), which to my knowledge they are not. I know RUF uses the quarter intakes on the new CTR. I wonder if they pitched them so that water drains out when in rain or spraying. I'm skeptical of the exhaust coming so high up into where the oil tank normally is, but on both sides. Seems like it would be a major heat problem especially with a 180-degree bend. Last edited by FrenchToast; 08-09-2017 at 06:32 PM.. |
There were some 968's and 993 RSR's that had them as well.
Bet that motor alone carries a comfortable six figure price on the options list.... |
Check out the guys garage that consigned it http://www.vaultgarage.com/news/vault-designed-furnished-garage-in-minnesota-appears-in-robb-report/ |
Formerly known as Syzygy
I wonder how effective "ram air" intakes in that location would be. Didn't Ruf try intakes in the fender tops right below there for the intercoolers on the Yellow Bird? The first examples had them but then they were dropped due to low pressure in that area and low air flow. Maybe the rear of the window has enough pressure compared to the fenders to add some extra air flow.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 08-09-2017 at 08:50 PM.. |
From what I understand, this is only the tip of the iceberg. There is a chassis (much like the new RUF) to go along with this engine, and word is its bonkers. Heaps of aero, roughly 2000lbs or perhaps less. Also expect the actual HP figures to be well clear of 500HP, more like 500 on a chassis dyno.
From what I understand, the engine will remain aircooled as in no watercooled heads. As far as what they did to keep the cylinder head temps in check, there are incremental changes to many of the systems, martials changes, but the big news is in the combustion system. Stay tuned.
(kg/lb) Last edited by Antonov; 08-09-2017 at 09:40 PM.. |
Many steep challenges to doing that, especially on pump gasolines.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Absolutely.
(kg/lb) |
Robert. 1976 930/934 Turbo Carrera RRS, Cristine She can be evil but oooh so much fun ![]()
Almost Banned Once
- Peter |
It look to me more like an artistic rendering of the project at an early phase.
A lot of details are questionable... I understand that they get support of Mezger the man himself, that is well aware of the issue to cool the heads, Porsche went water-cooling with the 4 valves heads for a reason. Williams may be well versed with F1 technology, building an aircooled engine might for sure represent a challenge. Enlarging the fan, and targeting 9000 rpm while still having an overdrive pulley ratio is the opposite of every factory evolutions. I would expect a more efficient system based on optimized oil cooling and a fan as small as possible. The timing chain seems also to still drive a single sprocket, while it's not uncommon, I dont see much space for the required gears to drive the 2 camshafts per sides. Exhaust primaries are just huge even compared to the most extreme racing engines. Starting with a now hard to find 964 case seems also not the easiest route while Porsche are still producing Mezger short blocs for the GT3 cup. I salute the project and look forward to see it coming to life, but for now, I believe that this rendering have mostly been disclosed for advertisement purpose |
Looking back at the original specs in the first post it mentions upper and lower injectors. I wonder if that references direct injection on the lower side and more standard intake manifold injection on the top. I read recently how a 2 phase injection scheme with direct injection, among other things dramatically cools the A/F charge. Could this help keep things cool enough? I still would not be surprised if the heads are water cooled.
I would not be surprised if Singer dipped into some sort of building its own chassis. There is not that many 964 chassis out there and they are getting really expensive. I think the exhaust primaries look so big because the entire system is double wall to keep noise and heat at a minimum.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Diss Member
More HP means more heat. + Heat builds in the heads. + Whole top of the cylinder head has limited cooling = Aluminum puddle in your top end. Where did they change the formula that Porsche didn't see? They mention dual oil circuits and my only guess is an oil circuit just for getting heat out of the head? It could work but oil is not the most efficient way of transporting and dispersing heat. (Water is actually shockingly efficient at heat storage and it is easy to transfer heat to and from water.)
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Eng-o-neer
Here's an "air gap" pipe, but it doesn't seem to do any muffling, just thermal control (primarily for catalytic converter efficiency): http://www.walkerexhaust.com/products/pipes-tubing/air-gap-pipe Last edited by Tremelune; 08-10-2017 at 07:23 AM.. |
Singer : new air-cooled 4.0L 9000rpm 500hp engine
Check it out. Just as the title says. Better have deep pockets guys
![]() Singer Creates New 500HP Porsche Engine With The Kind Help Of Williams ![]() ![]() ![]() ![]() ![]() ![]()
1986 930 Guards Red Too much to list...Lot's of HP |
Yep...
New Tread started yesterday...... http://forums.pelicanparts.com/porsche-911-technical-forum/965910-4-0-n-500hp-9000rpm-mezger-williams-f1.html |
My bad, late to the party lol
