Oil Valve for Changes
I just read about Fumoto Oil Valves that can be used in place of your normal oil drain plug. Changing the oil on my SC is a bit of a pain, and always somewhat messy. This sounds like it would make the whole thing much easier.
Obviously we'd need two valves. What do you guys think?
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! |
Fleabit peanut monkey
I like it for the oil tank. When that baby is first unplugged it's scary with respect to volume.
Not sure of the hang down on the engine sump plate.
1981 911SC Targa |
Reinstall the factory sump plug with antisieze. The Fumoto valve is too long for the sump. Install one in the oil tank. Good mod.
Burnin' Rubber
I've been using 2 on my 911 for years. They work great and make oil changes easy. I got a slim oil pan container that fits just fine under the car without raising it and it holds 16L so it's perfect.
Oil changes have never been this easy ![]() Btw, the hang down is fine on the sump plate because when fully tightened the nozzle orientation is not sticking out underneath. It's out of the way. Just make sure upon initial install, you use new washers. The valves are kinda Ronco, aka set it and forget it
![]() Sherwood |
Less brakes, more gas!
I've had the non-hose tip version on my oil tank for 20+ years... Its awesome. Car is too low to put a valve on the sump tank.
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Vintage Owner
There are several models available. Are they all the same size or what size is needed for the oil tank and sump?
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Chain fence eating turbo
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Interested.. for my 81 SC
Does our host sell these? All I see is this (which does not have a hose adapter).. It is not listed as a Fumoto.. 1981 Porsche 911 SC Coupe - Oil Circulation - Page 1 I also looked up on the Fumoto website and it provides 2 items for my model. Search Results | Fumoto® Engine Oil Drain Valves Size is listed as a M22 x 1.5 - Is this correct for the tank? Also no hose adapter listed for either - is that sold separate? or am I looking at the wrong part number?
1981 911SC |
According to the website posted, there's only one valve available for your MY 911. I guess the valve with the hose adapter isn't available in a size for 911s. Shouldn't that make shopping easier? And I wouldn't install that valve in the crankcase. Oil tank, however, is fine.
Reiver
De Oppresso Liber Strength and Honor 5th Legion |
Just a follow up- I believe the Fumoto with the nipple is part #FG7BNS Find Fumoto® Products | Fumoto® Engine Oil Drain Valves FG7BNS | Fumoto® Engine Oil Drain Valves M22 - 1.5 pitch - for the SC tank. I have a 81 SC (3 ltr) and Ive read that the nipple hangs down too low.. still pondering - maybe I can remove the nipple after draining..
1981 911SC |
the FG-7B N series (hose nipple version) is available here for $26.95+ship
https://www.xtremediesel.com/fumotoengineoildrainvalvefg7b.aspx I just ordered one.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 12-04-2017 at 06:13 AM.. |
Fumoto has recently added new models which should fit a lot of Porsche models, including Cayenne.
There are lower profile models, short nipple models (for attaching a drain hose) etc. and adapters that plug into the end of the valve to attach a drain hose to, including straight and right angle adapters. The hoses,adapters,etc. are amazingly inexpensive,like a dollar or two and the valves now come with a clip that secures the valve lever. I have a 1994 Mazda MX-6 LS that I bought new and installed a Fumoto drain valve on when it was new and have used it to easily change the oil since 1994. SAME valve...never any problems and always works. And that’s after 24 years and a lot of oil changes. I just stick a hose on and drain it into a gallon container (empty washer fluid container, plastic juice bottle,etc.). Get one for your Porsche and you will no longer need to take out drain plugs or replace the washers-VERY highly recommended if you change your oil yourself. They only cost about $25...best $25 I ever spent for car stuff. |
'73 911 T Targa
For the reason Al suggested, I think it makes sense for the tank, but for the sump, I don't know.... It seems awfully exposed, at least on my car. If you hit something and it rips that valve off, it's gonna be bad. I'm not sure I like how much the plug hangs down!
Heck, I’m only 5 not 71!
I installed a ball valve on the tank on my 80SC many many years ago and have had a smile on my face every time I've done an oil change ever since.
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
Unscrewing the drain plug on the oil tank doesn't worry me. 30 second job. The bit I don't like is changing the filter. My car doesn't have a sump drain plug so that makes that part easy .
I have Fumotos on my truck, wife's car, my bike, and my Porsche. Wouldn't be without them.
Marv Evans '69 911E |
The one that I have on the oil tank of my 72 is great. It's a strange angle with the wrench getting the plug out, and invariably makes a mess.
______________________________ Dave 1969 911T Coupe 1972 911E Targa |
I'm using the aeroquip version on my 911 & 996. very low profile so the ground clearance is not a problem for the tank.
http://aeroquipperformance.com/i-16532081-fcm3133-quick-drain-oil-pan-coupling.html Last edited by Harpo; 08-25-2018 at 06:57 AM.. |
