-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   My 3.0L Under The Knife (Rasant Products EFI conversion) (http://forums.pelicanparts.com/showthread.php?t=975084)
pmax 10-29-2017 01:38 PM
^^^ I don't see that in the OP's pic
justjones 10-30-2017 11:34 AM
Yep exact same set up on mine, its a modification of the original dizzy that turns the mechanical crank pick up into a digital signal the ECU can use (not an expert). That set of picture just doesn't happen to show it, I can post a picture of it but its already been done above ;)
pampadori 10-30-2017 01:37 PM
THat turned out very well! I have a pretty similar setup but went with Triumph ITBs to save the money ($100 per side on ebay with rails and injectors is hard to beat!).
I'm down on power about 15hp compared to your setup but it might be time to look into SSI exhaust.
Would you care to share your ignition map on this thread?
