French Import
zippy_gg's Avatar
Need to replace dog teeth...
I am replacing the dog teeth 1-4 with new ones from Pelican, but I do not have the special tools to remove the old ones.
Does anyone know of a shop in the Atlanta area that could do this for me? Preferably near Marietta.
Alternatively I could beg, borrow, or rent the tools from a Pelican.
I have a hard deadline as I need to move out of my rental house by November 22 and the transmission is still apart, and I am remodeling the house I am moving into.
Any suggestion would help.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 10-27-2017, 07:47 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Carefully cut the teeth off with a cutoff wheel. When you get close to deep enough, open the cut the rest of the way with a cold blunt chisel. Do at least a few cuts. The ring is an interference/press fit on the gear nubs, so it should pop apart when you give it a good strike with the chisel, so long as you've weakened the ring enough with the cuts to make it break
To install the new dog teeth, heat the teeth in a toaster oven (300F) and cool the gear in the freezer for several hours to ensure it shrinks as much as reasonably possible. The teeth will drop right on to the gear. Have something handy to pop the ring a few times if it doesn't drop all the way flush with the gear. A rubber mallet works good.
The gear and teeth will rust almost instantly. So have some WD40 or whatever handy to coat the gear after it's cooled off for a few minutes.
Kevin L
'86 Carrera "Larry"
Old 10-27-2017, 08:52 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Just a piece of info I am throwing out here. I had my trans rebuilt by a well known shop 10 years ago.
Works well except sometimes it balks going into third. I was told it would balk for several hundred miles but it still does a touch.
I think it has to do with some kind of a back cut or filing on the teeth of something or other. Either the synchro or the dog teeth.
I have an e-mail from Matt Monson explaining the issue. Let me find it.
If it's something you can do before install on any new parts that this may be applicable to, now is the time.
Sorry so cryptic. I think his e-mail will explain it better. May not even be applicable.
Stay tuned.
1981 911SC Targa
Old 10-27-2017, 10:14 AM
gearhead
Galen Bridges is in Marietta. Jack Lewis is in Norcross.
You don't need to worry about the backcut if you got them from Pelican and they are R&S brand. Since they first started making them they started adding the backcut. The information I provided to Bob is no longer important unless you buy the German OEM marked ones.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 10-27-2017, 11:42 AM
Under the radar
Trackrash's Avatar
It is prudent to check the diameter of the newly installed synchro ring. Five or six years ago I had a dog tooth bought from our host that did not have the back cut, FWIW. Good thing I checked. If it maters, PN 10-1550-316-M184.
At that time I replaced several dog teeth, both on my trans and another I helped rebuild. Even after heating the dog teeth I still needed to use my press to seat them on the gear. YMMV.
Gordon
'71 911 Coupe 3,0L outlawed
Old 10-27-2017, 03:19 PM
French Import
zippy_gg's Avatar
Thanks for the replies
Here is what I got:
Manual Trans Gear Teeth
Brand: OE Supplier Note: 3rd-5th Gear, Engine Type: 3.2L 3163cc H6 (3.74x2.93; 95.0x74.4) (1986 Porsche 911 Carrera Convertible)
Part #: 901-302-242-03-INT $99.25 2 $198.50
Gear Teeth (symmetrical teeth)
Brand: German Note: 2nd Gear (1986 Porsche 911 Carrera Convertible)
Part #: 10-1550-316-M127 $116.75 1 $116.75
Gear Teeth (1st Gear) (asymmetrical teeth)
Brand: German Note: (1986 Porsche 911 Carrera Convertible)
Part #: 10-1550-312-M127 $116.75 1 $116.75
So it appears that 1st and 2nd gears are German, while 3rd and 4th are OE Supplier (not sure what this means).
Which ones do I have to worry about having to file a back cut?
Gilles & Kathy
Old 10-27-2017, 05:23 PM
gearhead
Those don't have the back cut. Rausch and Spiegle are the ones who have added the back cut in the last year or so.
If you are willing to ship your stuff out, Jerry Austin offers a service to install and cut them. I think his username is imsa84
1974 914 Bumble Bee
2009 Outback XT
Old 10-27-2017, 06:47 PM
Buy the tools, use them, and resell them when you are done. Don't mess with the carefully cutting the xxx stuff, especially when you are pressed for time.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-27-2017, 06:48 PM
French Import
zippy_gg's Avatar
Thanks Matt, that's a relief!
I did a search for Galen Bridges in Marietta but nothing came up...
Gilles & Kathy
Old 10-27-2017, 07:20 PM
jackb911's Avatar
Goldcrest Motorsports on Moon Station Rd. in Kennesaw
Here's the link to their website: Main | Goldcrest Motorsports
Jack
2007 GT3
gone but not forgotten: 1987 Carrera IROC backdate, '89 Carrera M491, '96 993, '93 964 RSA(two), '00 996, '97 Boxster, '79 911SC, '78 928, '76 924, '75 914, '74 911, '74 914, '72 911E, '72 911T/V, '71 911T, '70 911T, '66 912, '65 356C, '61 356B roadster, '60 356B
Old 10-28-2017, 10:48 AM
Schleprock
KTL's Avatar
Jerry's username is Porsche84
Galen's username is z930
Kevin L
'86 Carrera "Larry"
Old 10-28-2017, 12:41 PM
French Import
zippy_gg's Avatar
Thank you Jack, I'll ping them on Monday. They are really close to me!
Gilles & Kathy
Old 10-28-2017, 05:17 PM
French Import
zippy_gg's Avatar
Thank you Kevin.
I send him an email, but his last activity on this forum was a year ago. Fingers crossed since he is not far from me.
Gilles & Kathy
Old 10-28-2017, 05:18 PM
gearhead
Keep in mind most of these guys are at PCA Daytona this weekend. Might not be back in their shops by Monday.
1974 914 Bumble Bee
2009 Outback XT
Old 10-28-2017, 06:29 PM
French Import
zippy_gg's Avatar
Great referral Jack. I called them this morning and then dropped my parts to them. I should have them back by tomorrow.
I dealt with Steve, a nice guy.
Next steps will be to put the transmission back together with the jig (thank you Brother Jim for the loan) and check the selector forks positions before final reassembly.
It is a bit of a race against the clock as I need to be out of our rental home in 3 weeks.
Gilles & Kathy
Old 10-30-2017, 05:03 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Break a Leg Brother!
'85 Carrera Targa
PCA/POC
Old 10-30-2017, 07:20 PM
