Mr. Amalfi
Question on Brembo XA5C201 Monobloc Calipers
Greetings,
Would anybody know whether Brembo XA5C201/202 monobloc calipers will fit on a 997.2 ?
Regards,
Jim (aka 'Mr. Amalfi')
Old 11-12-2017, 08:35 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hello Jim - I just did some research and it looks like these are for only the 993 and 996 - other members should confirm if they're able to fit them on a 997.
Old 11-13-2017, 04:51 PM
Mr. Amalfi
Hi Dmitry,
Thanks for the investigation.
I also had done some investigating, having gone to the Brembo site for application information. I couldn't quite tell from their info, but as you mention it seems they were for the 993/996.
One of the shops that had actually done the install on my factory-turbo-powered 993 C2 also weighed in. Says "....different mounting bolt pattern, and different rotor offset..." I had an purchase inquiry from a person with a 997.2. I didn't know if there were mounting brackets that would work as well as some hats, but at this point I'll just tell the person "....it's probably more trouble than it's worth..."
Thanks, again.
Jim
Old 11-13-2017, 05:50 PM
Tags
brembo , calipers
