930 turbo calipers with alcon front rotors and Pagid pads. never a problem
79 930 405 rwhp,84 911 track car |
Eng-o-neer
How'd you get the 3.6 smog legal? I'm struggling to fit the OEM exhaust and intake.
Guest
Posts: n/a
I honestly like your truck as well as the 911! Awesome!
964 heat exchangers with cat can be used however the crossover pipe has to be modified to clear 915 clutch linkage. The referee I have gone to allows headers with a approved cat to be used also. He says they are ok since there are no CA approved headers and it is a motor swap. I was not going to argue. Factory air cleaner car fit with some trimming. Car needs a check engine light also.
Thanks. It started out with a free used 930 turbo I put on a crate 350. Six months later it finally blew a head gasket when I put 14lbs boost in it. I already had a 383 small block with low compression Mahle pistons ready to go in next. Got a 76mm Garrett ball bearing turbo on it now also. Makes about 600hp 600tq on pump gas. It out ran my 480hp 965 when I raced my son at local drags. I did have drag radials on truck though.
Nice project that is coming along well. Mark helped alot, (alot-alot ) with sorting my riviera blue rsr, not to mention building the 3.8 and trans to back it up. I am more than happy to give him some tips on the backdate, this is going to be an awesome car!
Follow me on instagram, @flyin.hawaiin www.davekealoha.com |
Rennch on YouTube
Psyched to see this progress!
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
Looking good Mark! I must have looked at the ad for that car 10 times. It got plenty of use in the PCA TT series, seemed like a super reliable (and fast) car. You gonna let Erik go for the TTOD again when it's done?
I'm interested in seeing the progress as well! Converting race cars to street/track duty is something that I want to do too!
23 Macan GTS 97 240SX 94 Land Cruiser Too many Miata's to count. |
I would love to at least let my sons run it again at the stadium before they bulldoze it. As far as TT/de use it might have to be up to the next owner. I was very busy in the recession buying up cheap shorthoods and building them into track cars and always tried to sell them to local buyers. It has turned out to be a very good source of cars for me now. I have bought back and resold a black SC 3.6 car four times now and it has never left town each time.
Hey Mark,
I was referred to you by a friend on the forum. I just picked up a 1983 SC coupe with turbo flares. I plan to make a project of the car and am considering replacing the SC engine with a 993 3.6L engine from Instant G. I see that your SC has a M64 engine which you indicate is emissions compliant. Can you give me any information on what is involved in making a replacement 993 smog legal in CA? Thanks and best regards, Greg |
(man/dude)
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Good luck, Mark
Mark, what will you use for sound deadening on the rear seat and parcel shelf?
Johan
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
There is a very light version of the factory pad that we use a lot. Looks almost factory and doesn't fall down like the original ones do. Car should be painted in about two months. Stop by sometime.
Eng-o-neer
Is that the pad in the engine bay or the one behind the seats?
Also do you know if you can pass with a cone filter vs a factory air box? Edit just saw your response to runner4fun. Last edited by F1addict; 02-20-2018 at 03:08 AM.. |
3.0 exhaust could work just make sure converter has the correct number on it. The ref is pretty far south at a junior college in chula vista. I need to look up name of college
Thread Tools | |
Rate This Thread | |
