Help needed in choosing tire sizes
Hey all, I have a 1981 911sc which is lowered to Euro height. I am looking to put 7x16 front and 9x16 rear wheels on it.
After reading a few threads I'm not clear on what size tires I need to put on them.They all state you can put 245x45x16 on 8 inch and on 9 inch. Wouldn't the 245x45x16 look too small on that size rim? Could please someone clarify. Cheers |
Sent from my VS501 using Tapatalk |
245/45 x16 are spec'd for a 7.5" to 9" wheel, you will get the best performance by using a 9" thew 245/45 is ~.2" shorter than 225/50, if the optics bother you drop the car another .2" The primary benefits of the 245/45 over the 225/50 is a little wider tread on a little more stable carcass w/ a little better net gearing
The 245/45*16 is also getting harder to come by. Not many to choose from. I went with 7" and 8" rims, with 205/55*16 and 225/50*16 tires.
Havenīt regretted it once. Sidewalls are near identical and they fill the wheel wells nicely. ![]() PS! Mine is a bastard 77 911S with SC flairs and 964 bumpers, but you get the idea.
-------- 1977 911s |
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Thanks for the insight guys
| Tags |
| size , tires , wheels |
