Valve adjustment
Hello, my name is nick and I adjust number 6 intake valve by feel. There, I said it!
Old 02-15-2018, 09:43 AM
Ha... Sounds like an introduction at an AA meeting.
Good for you. May be just as accurate as wedging a feeler gauge in there that you can't see.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 02-15-2018, 10:05 AM
proporsche's Avatar
Hi Nick i`m Ivan and i am not.........anyway i do not use feeler gauges when i adjust valves. Been doing it by feel since the 1980`s...congrats
Ivan
1985 911 with original 501 587 miles...807 226 km
Old 02-15-2018, 10:25 AM
Well, here is something even better for the thinker..
The thread pitch is 1mm, think about it.
Bruce
Old 02-15-2018, 10:27 AM
One of the best air-cooled mechanics in town told me that some of the valves must be done by feel. Like number 6.
Old 02-15-2018, 12:54 PM
proporsche's Avatar
Nick+10000
i wonder who told you that;-)
Ivan
Old 02-15-2018, 01:25 PM
#6 intake says "bro... you really hit my right in the feels"... "you really know how to feel your way around my intake"... "I never knew you had feelings for me"... "did it feel as good for you as it did for me"....
don't forget to tip your waiter!
1987 Porsche 911 Carrera Coupe
Old 02-15-2018, 01:42 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
It's true, after you have done enough of them, you can get pretty close just by feel. That being said, I still use a feeler gauge when setting but for checking, by feel.
1986 Targa Guards Red
2021 MT09 SP
Old 02-15-2018, 02:41 PM
Still using a feeler gauge. #6 too.
206 637 4071
Old 02-15-2018, 04:12 PM
DWeg1998's Avatar
I’ve only done two valve adjusts and still could tell by feel if I got it right or not as a final check.
Old 02-15-2018, 04:31 PM
Functionista
manbridge 74's Avatar
I always check with feeler after doing by feel. Usually dead on.
Pro tip: when holding tool sideways on exhaust valve it should just be tight enough to keep tool from falling/moving under its own weight.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 02-15-2018, 05:13 PM
If you can slip it in and out easily without giving it a couple of light twists, it's still a tad on the loose side.
206 637 4071
Old 02-15-2018, 06:58 PM
Bill Douglas's Avatar
Well done.
I check them all by feel but use the gauge on the rare occasions I have to adjust one.
Old 02-15-2018, 07:09 PM
Formerly known as Syzygy
Canada Kev's Avatar
I use a feeler on all, even #6 intake. It's not that tough to get to. But I have smallish hands, so that may help.
Kevin
Old 02-15-2018, 07:15 PM
Registered Loser
Sounds like a couple ex girlfriends I had!
Current Rides:: 1987 Red 911 Targa, 2007 R320 CDI, 2003 Red Dodge Ram Hemi, 1993 Beater Jeep Cherokee, Airbus A320
Gone but not forgotten: 1981 VW Scirocco S, 1989 Honda Accord Coupe LXI, F-16C (still my favorite vehicle!),MC-130P, C-130E, T-38, T-37, C150, C172, PA180
Old 02-15-2018, 07:28 PM
Chain fence eating turbo
Bruce
Fingertight, then 1/10turn CCW
Old 02-15-2018, 08:04 PM
proporsche's Avatar
tippy+1
Old 02-15-2018, 10:57 PM
New-ish 911SC Targa Owner
pampadori's Avatar
amateurs...
I do it by hand AND sound....while the engine is running! it hurts a little but is the most bestest.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 02-16-2018, 05:48 AM
Peter Zimmermann's Avatar
Ex-act-a-mundo. And yes, a feeler gauge is necessary. You don't have to "see" the gauge, you only have to "feel" it. You wiggle the rocker to break the oil lock, then you adjust it. When it's snug you pull out the gauge, but always make sure you can re-insert it. If you can't put it back in, with a wiggle if necessary, start over.
ALWAYS be sure your gauge is in good condition, and has no scratches or dents. If it isn't dead smooth, break off a chunk, dress the edge of the new metal on your bench grinder, and go at it. If you use the type of gauge that has the short section held with screws and a small plate, replace the gauge piece.
At my shop we used a long piece of shim stock, about 8-10", held in a handle. That allowed us to break off a piece that was used up, pull the stock through the holder, and then dress the edge where the break was. Much easier to use. 1-6-2-4-3-5.
Keep the Shiny Side UP!
Pete Z.
Old 02-16-2018, 03:53 PM
Island911, over in PARF made a bunch of these years ago. Awesome.
206 637 4071
Old 02-16-2018, 05:07 PM
