billh1963's Avatar
1986 Carrera - what are sport shocks?
I think it's time to change the shocks on my 1986 cabriolet. The original window sticker shows that the car has "sport shock absorbers" as an option. What would that mean in terms of todays offerings?
Thank you
Old 04-02-2018, 01:05 PM
gtc gtc is offline
abides.
gtc's Avatar
Green Bilsteins
Formerly "HD" but now B6 or something like that.
Graham
1984 Carrera Targa
Old 04-02-2018, 01:15 PM
billh1963's Avatar
Thank you
Old 04-02-2018, 01:45 PM
Administrator
Dmitry at Pelican Parts's Avatar
I've included a link to our Suspension section for your 86' cab - please let us know if you have questions about any of the items.
https://www.pelicanparts.com/catalog/SuperCat/0809/0809-Suspension-Steering.htm
Old 04-02-2018, 01:49 PM
Fronts are likely "inverted" in that the body of the shock is on the top compared to the shaft of the shock being on the top with the standard shocks. That means you have to buy inverted style fronts.
Rears *shouldn't* matter what the car came with. Best to look though, as who knows what these cars have been through over the decades. The giveaway up front is the roll pin above the ball joint bolt:
Matt - 84 Carrera
Old 04-02-2018, 02:44 PM
Eng-o-neer
Tremelune's Avatar
If you have Bilsteins on there already, you can have them revalved for less money then a set of off-the-shelf shocks. From what I've read, they will perform much better than stock with a modern digressive curve. The downside is that you have to talk to someone at Bilstein or Elephant or some race shop, and it can take weeks to have the work performed.
If you don't want to wait, I think you could buy a used up set and send them off to have the work done.
I've never done this myself, but it's a perpetual plan for when I replace my shocks.
Old 04-02-2018, 04:51 PM
iwhelan's Avatar
My '87 has the sports shock option on the original window sticker, but has black shocks all around without any kind of branding on them. I have no record of these being replaced at any point, so I'm not sure if they're original. They seem fine considering their age if original. Any idea if the green Bilstein shocks would have been on my car from new in '87?
Old 04-04-2018, 07:00 AM
Originally Posted by Driven97 View Post
That is a VERY CLEAN undercarriage/suspension!!!!
Definitely inspiring to get mine cleaned up and looking this good!!!
1987 Porsche 911 Carrera Coupe
Old 04-04-2018, 07:53 AM
Thank you
Do you think the originals are still on the car? or is there something when you drive it that tells you that your shocks/suspension need to be changed out?
Old 04-04-2018, 11:34 AM
In '86-'88 at least, Boge was standard (and they are black). I am not sure if Boge made a HD version as an option. When it was time for me address new shocks on my car ('87), I put Bilstien HD inserts in front, and special digressive valve Bilstiens in back.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 04-04-2018, 03:01 PM
Dial 911
A horse with no name's Avatar
Hi...Our '86 Cab also came with the 'sport shock' option...They were black Boge's front and rear.
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 04-04-2018, 10:02 PM
^ Same here. My '88 has the factory sport shock option and has black Boge all around.
Model # on the front strut is 911.341.041.05 which is the sport version.
-Vince
'10 Carrera S
'88 Carrera Targa (sadly sold)
Old 04-04-2018, 10:32 PM
Bill Verburg's Avatar
For the 3.2 Carrera, M474 was the sport shock option
they could have been either Boge or Bilstein
Bill Verburg
Old 04-05-2018, 07:16 AM
guess this thread is getting off track....so the question...."What would that mean in terms of today's offerings? or what is available now that is comparable to what they had on back in the day.
Old 04-05-2018, 07:36 AM
Bilstein b6 aka hd are the same shocks as were used from at least '73 as the sport option.
Struts & shocks
There are other more current options that will cost more
Bill Verburg
Old 04-05-2018, 08:28 AM
