If you keep stretching, 245 on a 9 in wheel fits. I have 18x8.5 ET25 front wheels.
If you don’t want to stretch it as much, 912 front hubs will move the wheel inboard 7mm but that only works with stock brake calipers and torsion bar front suspension. |
What?
Hi Chris, nice work! I'm in Carmel, I'll have to stop by for a visit sometime.
Tom J. 911SC Cab SCWDP CaymanS |
scumbag
Full send into oblivion.Also, I didn't use any heat. I've only ever used heat when rolling a fender to save the paint. As I could care less if I futz up the primer on these fenders, I just started rolling them to see what would happen. Good to know that heat will shrink the metal if I find myself in need of a little shrinkage. ![]() I agree that Porsche quarter-a$$ed the front fenders when they pumped up the quarters after the middies. "If you want something done right...." Quote:
I'd really like to keep the 245s out back, but I worry that the tires will look weird if I don't upsize them one size when I upsize the fronts. As a data point, PN runs 235/265 on 18s. I don't make nearly the HP, so 235/255 should keep me between the mayo and mustard. Quote:
My garage is a bit of a disaster, so LMK in advance and I'll tidy up...or you'll not have anyplace to stand. ![]() Update incoming!
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
scumbag
Hurley shirt! Updates two days in a row?
Don't get too excited, this one is going to be brief. I have got to start chipping away at the massive APRIL 1 deadline list. So I bled the brakes this morning to get that off the list. I also found that I capped off the brake reservoir overflow/breather nipple with a vacuum cap at some point in the past. I bet that's why I've had a long pedal a few times over the past two years. :facepalm: I'll pick up some clear tube this week and route that little bugger somewhere....or I'll cap it again and vent the reservoir cap. 50/50 The elephant in the room is the new ECU and its wiring. I've been putting it off because, well frankly, I'm a little intimidated. I get all the concepts of wiring an EFI, but ECUMaster uses some different terminology and I've never used CAN before. So I'm feeling a little out of my depth. In an effort to both make some progress and continue to postpone the beginning of the EFI install, I fabbed up an adapter to mount the new CHT sensor that is en route to me. I started with an offcut from a previous lathe project. ![]() A few minutes with the bandsaw and a lot of minutes with a hand file got me this far. ![]() Another nip with the bandsaw and a visit with the drill press got me to here. ![]() Now I don't have the new sensor, nor it's thread pitch or size. So I made another flat and then drilled a pilot hole. The sensor hole will be finished once I have the sensor in hand. This is the final location and overall shape of the adapter. It's right behind the passenger side blanking plate on the engine shroud. That means there's only three screws in my way if I need to service/check/change the sensor. ![]() You'll no doubt notice I changed the set screw. I fired up the lathe to modify a screw from my bin to have a wee point on the end to bite into the fin just a bit and keep it from moving. ![]() Ah heck! Kelly just brought me a present! ![]() I guess that's one more thing I can use to keep putting off the installation of the new ECU.
You’re moving along at lightening speed my friend! Seeing this new intake project come together is quite interesting. I’ve just learned about the plastic 964 intake “halves” here... Never knew that those existed until now - so cool.
(man/dude)
I have a great idea for you - one which I can't use since I'm going twin plug on the Rot Rod.... but it's the best kind of idea, one which will save a bit of weight (which I like) and eliminate some wiring (which I LOVE).
If you're using conventional COP units they can be a bit weighty. The Audi 1.8T units I acquired are pretty heavy. The pile of twelve of them is massive and weighs 6 POUNDS!!! With the EMU black you could fire 2-pin CBR1000 coils direct with the coil driver, only two wires to each coil, not 4. AND they weigh a jaw dropping 65g each compared to the 225g "smart" COPs.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
(man/dude)
Oh ok I was envisioning heat it to cherry red kind of heat but on second thought that might be tough on the rollers.....
scumbag
I don't think I've ever been accused of moving at 'lightning speed' before. Thank you. I'm just doing my best to document my experience. The plastic tanks are originally mated to a plastic center section with a modular throttle body. I'm not going to bother with all of that unless I run out of things to do and decide to get a DBW TB...you know...to cut weight and add complexity. Quote:
Will those CBR coils fit ok? Now I have something to google all day at work. Quote:
I'm considering making/buying a round roller to accompany the cylindrical wheel that came with the tool. Not sure how I'd cover it in urethane if I made one myself....but all steel would be interesting. I built a spreadsheet yesterday of all the pins for the EMU Black yesterday. I'm using that to ensure I leave myself all the wires I need, but exclude all those I don't. I'm hoping if I get that fully sorted, I can wire up the main trunk from ECU to bulkhead (round) fitting this week. Then I only have to wire from the bulkhead to the engine. That's the easy part...or so I've convinced myself. ![]() I can confirm that building the spreadsheet has done a lot to assuage my fears about starting this ECU project.
scumbag
CBR1000RR ignition coils with connectors ordered.
Dang it, Jonny. When Kelly finds out, I'm giving her your number.
scumbag
Focker,
The coils I ordered are all pn129700-4840. The listings show 2007 CBR1000RR. I got 7, so I should be all set.
Sounds good. Give me a holler if you need anything as at one point I had 2 full sets of coild, injectors etc.
Interesting point on the CBR coils. What makes that the EMU can fire those but the previous MS3X could not?
Verstuurd vanaf mijn Pixel 6 met Tapatalk
Diederick I drive a US import 1977 911. Formerly owned by a woman in California named Ginger - which appropriately led to the nickname. IG: no dedicated account but photos are posted with #ginger77 |
scumbag
The EMU Black was designed to specifically handle this...or 12 smart coils. If I ever get to the point of needing to run twin-spark, I'll look into modular ignition coil drivers like on B5S4 2.7tt Audis so I can keep running the CBR coils.
Rear flare
Are you going to also apply the same treatment on the rears as Joey did on Project Nasty? I believe he either flared or flared and dollied above the arch to maximize up travel in order to allow running lower ride heights.
The car is really coming along. I saw you driving outside at Luft last summer but didn’t see it parked earlier so missed checking it out better.
82 911 Backdate Widebody Project |
scumbag
Once the fronts are sorted, I'll move to the rears. I've already proven to have reached the upper limit in the driver's rear quarter. And I plan to run bigger tires this year, so I have even less space between the tire and the body.As I acquire more tools and skills, the car will continue to get better and better...until Jamie paints it. It's gotta be well-sorted ahead of that. Should be a busy year.
(man/dude)
The most efficient way to do this is to have a cam synch signal so you can fire each of the 6 circuits in the firing order but not sure if Chris has or is planning to go full sequential. Instead you can go wasted spark and batch injection but.... I'm not sure how many spark outputs the MS3X has but seems like they often require an external ignitor to put the system together. A single ignition output will often be used to fire 2 coils at once in a wasted spark setup, with the external ignitors used to actually fire the coils. I'd be using the CBR coils in my twin plug setup but they would draw too much current to fire two per ignition output. Instead each of my 6 ignition outputs will fire two smart coils, one top, and one bottom, for each cylinder.
scumbag
(man/dude)
It's OK to talk to yourself as long as what you say isn't a surprise more than half the time. Otherwise seek help.
I'm too busy coming up with fun ideas to actually go back and figure out where you are in this journey, exactly!
