Nice to meet you albeit very briefly at the food trucks.
Jim 911 Mint Green "RSC" #mintgrun 911 Gentlemen's Rallye 85 Carrera GP White 2012 C63 AMG Mars Red |
Weapons grade dickhead.
Great to see you, Kelly, and MD again, friend!
Wish we could have hung out more. ILYSMBB
1978 911 SC Coupe Build thread: http://forums.pelicanparts.com/porsche-911-technical-forum/1069069-i-always-wanted-one-these-78-sc-build.html
Full Send Society
I am not reading any of this because the level of jealousy I know I will feel is just too much to bear.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
scumbag
It was a blast. Everything I hoped for and more.
It was nice meeting you too, Jim. Quote:
The story is yet to come.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
Jim can help me convince you to come to Hill Country. Nothing cures Midwest March blues like Texas brisket and kickass roads.
-Tony Instagram: @Pablo_the_Porsche | @RuchlosRallye AchtungKraft #002 |
scumbag
The HCR car is in my driveway waiting for me to build it. The 911 will always be too low for that rallye. Nate and Matt and I spent a fair amount of time discussing the next build over the last two weeks. It's going to be pretty different from everything I've built prior. But I have to wait until I financially recover from Rennsport before I can even think about that.
I'm good with tools.
Would love to see you down here Chris..... My HCR car is currently in paint.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
scumbag
I estmate it'll be another year, maybe two before the 914 is even close to driving up and down my street with no glass and some kludged together neighbor-friendly exhaust.
Ha. Ha ha ha. Ha hahahaha.
Ass-engine Nazi slot car -- PJ O'Rourke |
Enginerd
What an epic road trip. RR7 was just like drinking from a fire hose for four days. It was a pleasure to meet you, look forward to next time!
1982 Guards Red 911SC, 1994 Riviera Blue RoW 993, 2020 British Racing Green Macan GTS Gone but not forgotten: 2017 GT Silver Turbo S, 2012 Guards Red 991.1 C2S, 2017 Carrera White Macan GTS IG: @pcar911fan |
scumbag
I have a real quick question for the brain trust and I'm hoping I get enough traffic in here that I don't need to make a whole new thread for this.
At RR7, I got a pair of CSF fender-mount oil coolers. (crazy good deal) The traditional method of mounting those coolers is in opposed fenders, but I was wondering if I can stack them and run them in the stock location. (still in series) The reasoning behind this query is four-fold. 1. I am averse to nilly-willy dropping $500-1500 in hoses/lines to plumb across the car. 2. I am averse to adding extra weight to the car. (the aforementioned, and possibly superfluous, lines & fittings) 3. The front right corner is the lightest corner in the car. Doubling the cooler in that corner would add weight in the exact correct place. 4. The car is already set up to accomodate one cooler in that corner. Those same resources would not need to be duplicated if both coolers are installed (literally) together. (air inlets and a cooler fan and whatnot) PLEASE DISCUSS. I emplore thee.
By "stack", do you mean one on top of the other so that the air flow from the first goes through the second? If so, then I suppose you can do that, but it may be that using just one is just as effective. The reason I say that:
Air-to-fluid heat exchanger effectiveness changes with air flow and temperature differential. The amount of heat can can be removed is proportional to the mass flow rate of air and the temperature difference of the air entering/exiting the cooler. Stacking the coolers reduces the air flow through both (air resistance increases) coolers. Stacking also changes the temperature differential; you're effectively feeding warmer air to the second cooler. Do you have any technical data on the coolers? I may be able to do the math for you... |
My $0.02: technically nothing "wrong" from a function perspective, however: The front cooler will get fresh cool air, and dump its spent, hotter, and slower air into the cooler on row two. Residual heat from both would have a soaking effect as well on each other.
However, if you look at the stack-up of coolers on modern cars, sometimes you have a radiator, with a trans or power steering cooler in front of it, and there is usually an air conditioning condenser in the middle of all of that. These are usually package-driven decisions, no doubt having them separate with good airflow would allow the engineering team to shrink the size of each cooler due to more efficient performance. If you do it, make sure you feed the stack with a decent, sealed, dedicated fresh air ductwork so at least you get some velocity at speed, where the fan will generally be useless and in fact, in the way. Anything over 30-40mph. Same goes for an efficient fan to help pull enough air through at idle / city traffic speeds. If you buy lightweight plumbing like the Starlight hose from Aeroquip the weight hit won't be huge, if you use hard plumbing that you yourself fab-up and small hose lengths as connectors your cost will be lower. Then there's the center-mount option for one of the coolers but that would add an aesthetic change to your car that I'm not sure would be a positive. Basically, the more efficient the flow to and through the heat exchanger, the smaller it can be. 956/962s had really thick intercoolers, but the trend has moved on from there in modern race cars, as has the tube/fin/basic design of intercoolers themselves. In a nutshell it's about efficiency in getting cooling air to go through the exchanger, with "bad" air, the coolers will have to grow to do their job through surface area, heat rejection. Why not run just one of them to start, and maybe with good ducting it's enough, due to the perceived higher efficiency of the CSF core.
Garen GNdesignLLC.com - Automotive Art & Sculpture |
Ha! I think fanaudical and I hit "post" at the same time! he basically says what I'm saying, in less words. Like a more efficient cooler...
Do you need more cooler than 1 fender cooler? Most street cars get by just fine with a good fender cooler and fan setup.
Even 993 that didn’t have an on engine cooler only have 1 fender cooler stock and that’s fine for most people. |
Great to catch up with all of you guys in person. Being on the other side of the world most of the time makes it more difficult, which is on of the great things about a global event like Rennsport.
As for the oil cooler. I agree with Evan above. Just fit the one for now. I have a similar sized cheap front mounted one (with no fans) that was designed for an RX7 from memory and even thrashing it on the track on a hot day it only gets up to about 230 oil temp.
See my 2.8RSR build on YouTube 'Home Built by Jeff' http://youtube.com/homebuiltbyjeff http://forums.pelicanparts.com/porsche-911-technical-forum/889676-home-built-hot-rod.html#post8868732 |
Stay with one cooler , sell the other for the "slippery slope" of things !!
With a carrera cooler and fan, I can't get Pablo's 3.2ss over 220F. That's mobbing uphill mountain passes at elevation where it's tough to shed heat. And Ravi's new coolers are better than the stock ones I'm running.
I vote stack 'em and and louvre the fenders.
I plan to louver my fenders for better air flow next year.
scumbag
I don't have any technical data, but I'm sure I could get some numbers out of CSF if I ask nicely. Quote:
At some point in the future, the engine-mounted cooler is going away and I'll relocate the oil tank from RR corner to smuggler's box. I expect this will add stability to oil temps because of the additional volume, but decrease heat-shedding due to the loss of one cooler. After reading your replies and considering all factors, I think the plan is to replace my Turbotrol with one CSF cooler. Then when the tank gets relocated, add the second CSF to the LF fender to ensure I have sufficient cooling capacity.
